@sledgy: This bike does not have a clear coat, it's a matte black paint, as you can see on the rest of the frame. (a bit higher on the top tube for example, closer to the display). Nowhere else on the frame it has the same wrinkles/folds pattern... If it's really common, can you show me some other examples of bike frames with this kind of pattern?
Sorry, I don't keep files of carbon fiber pics handy I just have experience working with CF for 20y and I understand the MFG tech involved in producing CF bike, moto, automotive parts. My understanding is that some folks didnt like the weave of plain or 2k 3k CF fabric and on occasion it can get misaligned in molds and look funky as the pattern is disturbed, so it is often used as the base layers of CF fabric to build the frame and the Unidirectional final layer of fabric, is basically to hide any fabric layup/alignment issues as it basically produces a plain solid matte black surface.
As for the paint/clear coat or matte,... often a satin clear coat on a naturally black unidirectional CF frame can look exactly like a matte black paint when the unidirectional CF fibers under the epoxy matrix are aligned and straight
when there is some movement as the layup is installed in the mold before it is baked and cured, unidirectional cf strands close to the surface can shift "out of alignment" so to speak, and can be visible at the surface yet that surface is perfectly shaped and smooth.
With out inspecting the frame closely I cant be 100% correct, just sharing what I understand of the tech involved. There are MANY frames and parts out there where you see patterns of Unid. CF in the parts, the issue you are concerned about is not a defect in the frame in my opinion.
NOW,...If that frame is indeed entirely matte black painted AND you are seeing some pattern in the frame..? but no surface defects that would seem to be a paint/finish issue..Vs a frame/manufacturing defect.
Maybe THAT as an issue, means you can get it for less than retail..? But patterns & lines like this are usually common artifacts of the CF manufacturing process when using unidirectioinal carbon fiber
Good luck!
