Strange pattern visible under paint on carbon frame — cosmetic or structural?
copier-tunnel6n
Hi everyone,
I went to check out a brand new Cube Stereo Hybrid ONE44 AT, model year 2026 at a local bike shop.
The bike has a matte black carbon frame, but I noticed something unusual on the top tube.
Under the paint, there is a strange irregular pattern visible.
It looks like darker lines or marks beneath the surface, almost like folds, wrinkles, or some kind of irregular structure or cracks showing through the finish.
I took two photos of it and I’ll attach them here.
Because this is a completely new bike, I’m wondering:
  • Could this be just a cosmetic issue in the paint or clear coat or could it raise concerns about the structural integrity of the frame??
  • Could it indicate a manufacturing defect in the carbon layup or frame itself (resin distribution, sanding, filler, or clear coat issues)?
  • Have any of you seen something similar on a Cube carbon frame before?
  • Do you think Cube would recognize this as a warranty / quality issue and replace the frame or even the bike before purchase?
Any opinions or experience would be greatly appreciated.
Thanks!
I am not any kind of expert on Carbon Fibre lay up, but it looks to me like folds in the mat or even the resin.
As a minimum, I would at the very least share your pics and concern with whoever you bought the bike from. Record their response and then forget about it! If something goes wrong later, you have the evidence.
I would also consult more widely with people that know what they are talking about.
I know that there are small workshiops in surprising places that make high tech carbon fibre components. My daughter's stepson, for example, produces very low volume carbon fibre components for a few of the car manufacturers in the F1 industry. Google "carbon fibre component makers" to see if there any in your area.
EDIT: It doesn't look anything to worry about "just cosmetic" as they say. If you are concerned put some helicopter tape over it (I always do) and that may obscure it enough.
By the way, where is your location? Even just the country would help.
That is just the carbon fabric visible thru the basically satin clear coat (as its already black) frame. The frames when black are often not painted over, just clear coated or possibly a dark tinted satin clear.
Carbon fiber fabric is generally a woven 2k 3k++ either plain woven or a hounds tooth type woven pattern ( much more common) .
You dont see a weave pattern as they use a unidirectional carbon fabric Vs a woven 2k-3k+ fabric alot more as the surface layer these days. Most CF wheels frames handle bars any more are all made with a top layer of unidirectional CF. it is very rare today to find a new CF wheel or frame that shows a carbon weave like the old carbon fiber Eastion Monkey Bars had. I think Unno still does it...
...As a minimum, I would at the very least share your pics and concern with whoever you bought the bike from. Record their response and then forget about it! If something goes wrong later, you have the evidence...
@steve_sordy: I didn't buy it yet, but I'm interested in buying such a bike, so I wanted some advice first.
No - why?
The frame is perfectly fine and every carbon bikes has this kind of look when it’s visible carbon.
@sledgy: This bike does not have a clear coat, it's a matte black paint, as you can see on the rest of the frame. (a bit higher on the top tube for example, closer to the display). Nowhere else on the frame it has the same wrinkles/folds pattern... If it's really common, can you show me some other examples of bike frames with this kind of pattern?
I was going to say it's normal for clear too, until I read your reply
so yeah it looks a bit suss to me if it's black paint or black gel coat,
is it completely flat? If it isn't then it's definitely dodgy.
@skizzian: I don’t specifically remember touching it to get a good feel for the texture, so I don’t know if it feels completely smooth. What concerns me is that the line in the middle (especially visible in the first photo) is so dark in color. It looks as though moisture has accumulated under the paint/coating or between certain folds and creases in the frame during the manufacturing process.
I have the Race 800 and had exactly the same concerns when I got my bike. I too have the worrying dark line, at least it did worry when I first when I saw it.
It is absolutely fine and just the raw carbon showing through.
Once you are over the fact that it's not a defect, you'll grow to like it, hopefully :)
I've had a lot of positive comments about the frame.
Hope you enjoy the bike!
I'm still not sure it's an opaque paint and it's a crease in the lay up
but https://mhw-bike.com/cube-stereo-hy...ne-2026-e-bike-fully-mountainbike-102200-main shows you this image - which seems pretty clean in comparison
The official product shots will be the nicest looking ones, or Photoshopped.
However, it's perfectly normal for raw carbon frames to look like that.
Buy a painted version if it bothers you.
yeah for sure, but the question seems to be whether it's a raw or a paint/gel coat black finish...
@Bonus : Thanks for your reply! Would you mind posting some pictures of your frame with good lighting and detail, for comparison?
I missed the point that you haven't bought the bike yet. :giggle:
If you are so concerned, don't buy the bike.
But be aware that underneath the paint of the next CF bike you buy, there may lurk exactly the same swirly pattern!
My bike may have the same swirly pattern underneath its red & black paint and I've had it almost five years.
Hi everyone,
View attachment 180674View attachment 180673
Thanks!
This certainly does not appear to be a flaw in the finish (I spent 50 years in coatings industry from product development to application systems) and is substrate related. Im surprised that frame made it through QC and assembly without being pulled for defect.
It’s definitely not defective. Please stop telling misinformation.
I have to admit that I’m actually a bit surprised that there are users here who consider this frame to be normal.
I’ve been actively involved with bicycles for 30 years (road bikes, city bikes, mountain bikes, etc.) and I have to say that I’ve never seen this kind of irregularity in a carbon frame before.
Even when you search Google Images for carbon frames, 95% of the results show the regular, typical checkered pattern of woven carbon fibers.
Occasionally, you might come across parts made of flaked carbon or forged carbon. But the photos of this frame here don’t even remotely resemble any of those.
It really looks like some kind of misaligned structure beneath the surface. It looks as if the carbon mats used in the manufacturing process were crumpled at that point. Something that looks like it should never have passed Cube’s quality control.
I’m curious, in the photos it also seems to show darker spots in the paint coating in addition to the surface irregularities… is that correct when viewed with the naked eye or is it just something from camera in the photos or posting of them?
It is unidirectional carbon. Those dark lines are wrinkles on the unidirectional carbon layer. The dark line along the center is parting line of the mold where they usually place the carbon fabric symmetrically on the top layer in the mold halves. That's how carbon bicycles look like without cosmetic layer of carbon or without paint. They may call it matte black, but this is raw carbon with matte clearcoat finish. Some people like how it looks like, some people don't, but this is not structural or cosmetic issue and it is how it intended to be. Consider it is like visible wood grain, some people like to see the natural wood grain finish on their furniture, and some people like to see just paint on their furniture. By the way, this is the cheapest carbon frame finish, most Chinese carbon frames look like that.
I agree with your analogy, you made an interesting comparison finished wood has two grades:
“Stain grade” is used when a natural or transparent color is clear-coated.
“Paint grade” is smooth wood without grain transfer, used for opaque finish.
If that frame was just clear coated carbon you would indeed see patterns, (personally, wouldn't mind that but I wouldn’t want the physical, topographical textures/folds) if its an opaque finish those irregularities are unwanted… as an example, no one wants a physical wrinkle in the middle of their car hood.
Yeesh, looks like a text-stutter…
    668K
