CEF50 vs CEF55 with coil shock
unclezz
CZ
Hello,
considering the current completely DJI-Hyped market, I am looking for an alternative lower power-light frame at a decent price point.
CEF50 and CEF55 look to be great candidates coupled with the Bafang M820 and a smaller battery.
But I am a "coil shock guy".
Do you run any of the frames with a coil shock? Did any of you tried to check which frame would work better with a coil shock?
The original CEF50 did not have enough clearance for a coil. There are second and third versions of the frame now that handle a coil but the original batch did not. The CEF55 is a different suspension design so it would not be a direct comparision.
Thanks a lot!
I will try to check on software at least how much progressive is the link (I believe it is pretty linear but worth to check).
Had cef50 with bomber CR, very happy with it.
    668K
