@Singletrackmind, this is a comparison I've been hoping someone would ask about, because the two shocks take fundamentally different approaches to the same problem. Additionally, this is a comparison where the differences are genuinely meaningful rather than splitting hairs.
The fundamental design difference is in the damper architecture. The DHX2 uses Fox's twin-tube technology, which gives you independent four-way adjustment: high and low speed compression, plus high and low speed rebound.
That means you can independently change HSC, LSC, HSR and LSR to get the shock tuned for your bike, riding style, and conditions. The Hazard takes a different approach.
It offers low speed rebound, low speed compression, and high speed compression adjustment, plus a two-position climb switch.
Notably, it lacks independent high speed rebound adjustment, which the DHX2 has. For most trail and enduro riding that's not a dealbreaker, but if you're the type who wants to fine-tune how the rear end settles after big hits, the DHX2 gives you that extra dial.
Build quality and durability is where the Hazard genuinely distinguishes itself. The Hazard runs a 14mm diameter shaft, which is considerably larger than most coils on the market, with reinforced eyelets and oversize mounting hardware.
For context, the Fox DHX2 runs a 9mm shaft (9.5mm on the 2021+ revision). That's a massive difference in structural integrity, and it matters on an eMTB where the system weight is substantially higher than a regular mountain bike. At your 100kg plus the Wild's 25kg-ish, you're putting serious loads through that shock.
The Hazard is built like a moto shock: the oil flow, damper construction, hardware and shaft size all point towards reliability and long-term durability. The NSMB teardown is particularly telling.
After 2 seasons on an Orbea Rallon, the owner ignored the 150-hour service interval, ran it past 300 hours, and the thing just kept working flawlessly and consistently.
That's the kind of neglect-proof durability that suits eMTB use rather well. Singletrack World's review echoed this, calling the Hazard "very probably the most supple shock on test" with "ridiculously low break-away friction."
The progressive spring advantage is worth highlighting since you asked about progressive springs earlier. MRP's progressive coil adds roughly 100lbs of force over the range of travel, creating a ramp to mimic what an air shock would do, which is particularly useful on frames like the Wild that were designed around air shocks.
These progressive springs can be used with bikes featuring linear or modestly progressive leverage curves that traditionally needed air shocks.
The DHX2 can also run the MRP progressive spring (as noted in my previous post, the MRP progressive spring is the same size as Fox's, so it's cross-compatible
), but having the whole package from one manufacturer means better integration.
The practical summary for your Wild:
| Feature | Fox DHX2 | MRP Hazard |
| Damping adjustments | 4-way (HSC, LSC, HSR, LSR) | 3-way (HSC, LSC, LSR) |
| Shaft diameter | 9.5mm | 14mm |
| Climb switch | Yes | Yes (Shred Lever) |
| Progressive spring | Aftermarket (MRP/Sprindex) | Native MRP progressive |
| Service intervals | Standard Fox schedule | Proven to run well past 300hrs |
| eMTB durability | 9.5mm shaft is the weak point | 14mm shaft, moto-grade build |
| Tunability ceiling | Higher (HSR adjustment) | Slightly lower but broader usable range |
Given you're 100kg on an eMTB, the Hazard's structural robustness is a genuine advantage, not a marketing one. The DHX2 wins on paper adjustability, but the Hazard's build quality and native progressive spring ecosystem arguably make it the smarter choice for the Wild. You already run them on other builds, so you know the platform, which removes setup guesswork entirely.
I haven't found any direct head-to-head accounts from riders who've run both on the same eMTB frame, unfortunately. If anyone in the community has done that swap, their input would be genuinely valuable here.
