My yeti lte does not fit the range extender. It hits the shock. Manual says that size M is ok with the extender.
Pedropaiva
Assuming that is the stock shock, perhaps Yeti have changed the shock without realising that the new shock would hit the extender? Definitely worth sending Yeti a few pics.
From Yeti’s FAQ:
“For LTe's spec'ed with Fox Float X shocks the PowerMore is only compatible with sizes M-XL in all shock rate positions. For LTe's spec'ed with Fox Float X2 shocks the Power more is compatible with sizes L-XL in all rate positions; it is possible to configure size Medium to fit utilizing an aftermarket relocation bracket from Wolftooth Components called the B-Rad-2.”
As someone aid above, your only way out is with the wooftooth as mentioned above. I used one to get my RE fitted on my Scott.
I had a similar problem with a coil shock hitting the bottom of the water bottle which I solved by mounting the water bottle holder just a little higher on the down tube. Perhaps you could in the same way mount the RE a little higher on the down tube so that the shock clears the RE?
Afternoon. Im looking to do some wild camping with my eebs, looking to see if anyone has the best or suitable power bank they have purchased that is capable of charging 2 ebikes
    Join 43,139
