SamIsHere
- Feb 12, 2026
- 4
- 3
Hi everyone
I’m building a compact USB-C eBike charger that lets you charge your eBike battery from a standard USB-C PD wall adapter (the same kind phones and laptops use).
I’m looking for a small group of test users to try it in real-world conditions and give feedback before I finalize the design.
What is it?
This is an attempt to make a slim and lightweight charging solution so that you can charge anywhere you are. The final size is going to be around 70x70x30 mm which is smaller than you phone.
You can use any USB-C adapter. It is able to use any phone adapter (~65W) to the strongest and newest bricks that are capable of 240W.
You can charge any battery pack up to 60 V. The output connector is an XT60, and I will provide adapter cables to the most popular battery connectors (ST3, XLR, Anderson, DC barrel jack).
At the end of the post I attached a few AI renders of how the charger will look like, just so that you get a general feeling.
What I'm testing
- Compatibility across common USB-C PD adapters and cables
- Real-world charging behavior (heat, stability)
- Usability: connector placement, cable strain relief, enclosure, indicators, etc.
Who I'm looking for
- You have a battery that charges via XT60, ST3, XLR, Anderson, DC barrel jack,...
- You can do a few test charge session and share notes/photos/comments
What you get
- I will send out the test prototypes without profit, this means that you cover only the material costs + shipping. Estimated material costs are around 50 €. I ship from Slovenia, EU.
- Your feedback will shape the final product and i'll credit the testers if you want.
- I expect to have the test prototypes ready within 6 months, if I fail you get your money back.
How it works
Before I ship the charger I will program it to your battery voltage. After that the charger is plug-and-play, no config, no app.
You use any USB-C wall adapter to power it and it will charge the connected battery to the programmed voltage.
Interested?
Reply here or DM me with:
What is it?
What I'm testing
Who I'm looking for
What you get
How it works
Interested?
- Your battery info (voltage 36V/48V, charging connector picture or type if you know it)
- Your location (for shipping estimate)
- Any questions you might have.
