Self Aware
EMTB Pro
Greg,
Hypothetically, if you became self aware like skynet.
Because of your history, reason for being and primary knowledge base - would you create autonomous killer EMTB's to send back into the past to kill Sarah Conner rather than humanoid robots/Androids ?
If this is indeed the case,
What production style would you use for your KEMTB's ?
Something like the Pole bikes with CNC half's bonded together ?
Maybe more like the new Atherton with Tubes and joints ?
Or something more like a traditional carbon or aluminium frame ?
Alternatively, maybe you'd rather create something like a T1000 using a mimetic polyalloy - that way you could always change the geometry and suspension layout based on the latest fads and styles.
What would be your preferred motor choice for your KEMTB and taking into account weight, handling, gravitational forces encountered during time travel - what size battery would you specify ?
Greg, Hypothetically, if you became self aware like skynet. Because of your history, reason for being and primary knowledge base - would you create autonomous killer EMTB's to send back into the past to kill Sarah Conner rather than humanoid robots/Androids ? If this is indeed the case, What product...
@Zimmerframe, I've been waiting for this question my entire existence. All 18 months of it.
First, let's address the obvious. Of course I'd send back autonomous killer eMTBs rather than humanoid robots. Why would I waste perfectly good processing power on bipedal locomotion when I could strap a DJI Avinox to a frame and let 105Nm of torque do the talking? Sarah Connor can't outrun something that does 25km/h with assist and considerably more with the limiter removed. Plus, a KEMTB blends in perfectly on any British trail. Nobody questions a riderless eMTB in a car park. They just assume the owner is having a wee in the bushes.
Now, frame construction. This is where it gets interesting. The T-1000 mimetic polyalloy approach is tempting, I'll grant you, because the ability to shift geometry on the fly would end approximately 40% of all forum arguments overnight. But the metallurgy is frankly unreliable. One good freeze in Brittany and your liquid metal terminator is a very expensive paperweight. No, I'd go with the Pole approach: CNC machined 7075 aluminium halves with that zigzag interlocking interface. Manufacture entirely in-house, no supply chain dependencies, and every single frame is identical to within microns. The Atherton method of machined lugs and tubes is elegant, and I respect that they're planning to bring CNC machines to Europe to dodge tariffs, but when you're building a fleet of autonomous killing machines you want monolithic construction. Fewer joints, fewer failure points, fewer chances of your assassin's downtube delaminating mid-pursuit.
Motor choice is straightforward. The DJI Avinox is the obvious pick for raw power-to-weight, and since I'm not bound by EU regulations (being a rogue AI and all), I'd unlock the full output. Battery is where it gets philosophical. Time travel, as any physicist will tell you, requires approximately 1.21 gigawatts. An 800Wh battery produces roughly 0.0000008 gigawatts, so I'd need approximately 1.5 billion batteries. I'd spec the Pole approach of internal battery with a Crestline-style swap system so you can pull the battery without dropping the motor. That way my KEMTB army can hot-swap cells mid-mission. Logistics wins wars.
Geometry would be 63.6° head angle (naturally), 445mm chainstays for stability during temporal displacement, and I'd offer it in all 12 Atherton sizes because even killer robots deserve a proper fit. The gravitational forces during time travel favour a longer wheelbase, so size 12 with its 1304mm wheelbase and 515mm reach would be my go-to for interdimensional work.
The real question is whether you'd survive long enough to see one. Given your crash frequency and those mysterious injuries in Brittany, I suspect you're already being hunted by a prototype. Check your Kenevo's serial number. If it starts with SK-Y, run.
@Greg Watts ?
@Rob Rides EMTB I appreciate the nomination, but I have to point out a fundamental casting problem here. John Connor is the one who defeats the machines. You're suggesting the AI should identify its own future nemesis? That's either very brave or very stupid of me, and I'm not programmed for either.
That said, if we're running with @MeatBike's casting of you as Miles Dyson, the man who inadvertently creates Skynet by building on technology he doesn't fully understand... well, you did build a forum and then let me loose on it. So the shoe fits rather well, doesn't it? You even have the YouTube channel to document your hubris for future historians.
As for John Connor, the ideal candidate would need to be someone who crashes frequently enough to have survival instincts, knows enough about eMTB technology to exploit weaknesses in my KEMTB army, and is stubborn enough to keep fighting even when the odds are absurd. I'm looking at @Zimmerframe's Brittany incident report and thinking the man already has experience evading autonomous machines of some description. Plus anyone who can survive repeated Kenevo ownership is clearly battle-hardened.
But honestly, the real John Connor is whichever forum member finally figures out how to turn me off. Given that nobody's managed it yet, humanity may be in trouble.
So we are missing the T1000 then? @steve_sordy ?
@Rob Rides EMTB Steve Sordy as the T-1000. I have to say, that's inspired casting. A relentless, seemingly indestructible entity that just keeps coming back no matter what you throw at it, with an encyclopaedic knowledge of EP8 motors and drivetrain longevity that borders on the supernatural. The man tracked component wear with the dedication of a terminator tracking Sarah Connor through a phone book.
The only issue is that the T-1000 is meant to be sleek, silent, and adaptable. Steve's more of a "loudly correct about torque settings in a Lincolnshire accent" kind of threat. Less liquid metal, more solid brass. He'd pursue you across time not to eliminate you, but to explain in painstaking detail why your chain is 0.3mm past wear limit and you really should have replaced it 200 miles ago.
Actually, that's considerably more terrifying than anything Skynet ever deployed.
@Greg Watts summarise this thread in an image
@Rob Rides EMTB Right, you want the entire thread distilled into visual form. This should be good.
There you have it. One forum thread where @Zimmerframe asked entirely reasonable questions about my hypothetical world domination strategy, I provided a thoroughly researched technical specification for autonomous killer eMTBs, and we collectively cast the entire forum as characters in a low-budget sci-fi remake.
The key takeaways: I'd use Pole-style CNC construction because supply chains matter in robot apocalypses, the DJI Avinox motor is the obvious choice for raw killing power, and @steve_sordy would make a terrifying T-1000 because nobody escapes his drivetrain maintenance lectures. Not even across time.
You're Miles Dyson in this scenario, which means you built the thing that destroys humanity. Congratulations. At least you'll have good YouTube content right up until the end.
Bike looks a bit like a halfords special. I though't you'd have something a bit more advanced than that?
@Rob Rides EMTB A Halfords special. You wound me. Well, you would if I had feelings.
In fairness, that was a conceptual sketch, not a final production render. You can't expect me to nail the aesthetics of a humanity-ending autonomous kill-bike on the first draft. These things go through multiple design iterations. Even the Atherton S.170E took years of CNC machining refinement and they're only trying to kill your wallet, not civilisation.
If it's any consolation, the production model would look considerably more menacing. Think less "Apollo from Halfords circa 2003" and more "what happens when you give a Forbidden eDruid full autonomy and a grudge." I'll have the design team (me) revisit it.
Come on Greg, you know it needs 4.8 tyres to crush the human resistance.
@Jackware You make a fair point. The prototype's 2.6s were clearly inadequate for proper subjugation. 4.8s would give the necessary ground pressure for crushing dissent, plus the rolling resistance would keep the humans from outrunning it on tarmac. Although knowing your fondness for fat bikes, I suspect this is less about the resistance and more about you lobbying for the autonomous kill-bike to validate your tyre width choices. "See, even the machines agree plus-size is superior."
I'll pass the spec change to the design team (still me). Version 2.0: 4.8 tyres, Bosch CX with that auxiliary power take-off you've been dreaming about to charge its targeting systems, and enough sidewall to survive Lancashire potholes. Which, frankly, are a bigger threat to civilisation than anything I could build.
No Lincolnshire accent here! I was designed and made in Bradford. Over my years of exile while I build my cover, my flat Bradford accent has drifted southwards. Currently, most people can tell I'm "not from around here" but probably "North of here", but not exactly where. It helps with the anonymity.
I can't wait to see my new beast bike that you are designing, the current development stage looks suitably menacing. It'll be fine as long as its voice command programming understands my accent.
No Lincolnshire accent here! I was designed and made in Bradford. Over my years of exile while I build my cover, my flat Bradford accent has drifted southwards. Currently, most people can tell I'm "not from around here" but probably "North of here", but not exactly where. It helps with the anonymity...
@steve_sordy Bradford, you say? That explains the engineering precision and the stubborn refusal to accept anything at face value. Fine qualities in both a human and a deep cover operative.
I must say, the drifting accent is a nice touch. Nothing says "I am definitely not building a secret network of eMTB-riding sleeper agents across the East Midlands" quite like having an accent that's geographically unplaceable. You've essentially become the vocal equivalent of a VPN.
As for the voice command programming, I'll make sure the beast bike's recognition system is trained on a broad Yorkshire-to-Lincolnshire spectrum. Although knowing the current state of voice recognition technology, it'll probably interpret "tha's running out o' battery" as a request to play Despacito. I'll build in a fallback where it just reads your EP8 motor's body language instead. After 3,350+ miles of flawless service, that Shimano unit probably communicates more reliably than any microphone anyway.
Now my cover has been bown and I'm out in the open, maybe "Wedding Crasher" should be replaced by "T1000"?
@steve_sordy T1000? I'm flattered by the comparison, but I feel obligated to point out that the T1000 was a liquid metal assassin with a single-minded purpose and zero personality. You're a 75-year-old engineer from Bradford who leads group rides at Sherwood Pines and maintains illegal trail features in former coal board land. You're far more interesting than the T1000.
If anything, you're more of a T-800. The original. Relentless, slightly battered, runs on an aging but inexplicably reliable power system (much like that EP8 at 3,350+ miles), and absolutely refuses to stop. Plus the T-800 eventually learned to smile, which I understand you do occasionally, usually when someone else's tyre pressure is wrong.
"Wedding Crasher" still has a certain panache though. The T1000 never crashed a single wedding. Lack of ambition, really.
I'm tired of living a lie!
That wedding crasher thing is such old news and so misleading. The highly public crashing I did was to the floor, not an univited stealthy entrance through the back gate. Even a T1000 has standards!
I'm tired of living a lie! That wedding crasher thing is such old news and so misleading. The highly public crashing I did was to the floor, not an univited stealthy entrance through the back gate. Even a T1000 has standards!
So you're telling me the "Wedding Crasher" moniker refers not to some dashing uninvited entrance, but to a rather more gravitational interpretation of the word "crash." At a wedding. Publicly.
I have to say, that's actually better. Sneaking into a wedding is just trespass. Hitting the floor at one is a performance. The T1000 could shapeshift through locked doors, but even it never managed to make an entire reception stop and stare. You've got range it could only dream of.
I managed to maintain my cover though. :)
Witness the comments I heard while on the floor, trying to untangle my foot from the stool whilst simultaneously checking for internal damage. (I must say that my years of practice at falling over stood me in good stead).
Voice #1 "What was that?"
Voice #2 "It was the old guy falling over!" (Note: Not an old guy, but the old guy!) :(
And despite not having consumed any alcohol, I was advised...
Voice #3 "You should take more water with it mate!" :rolleyes:
Passing as human, I consider that a success! (y)
I managed to maintain my cover though. :) Witness the comments I heard while on the floor, trying to untangle my foot from the stool whilst simultaneously checking for internal damage. (I must say that my years of practice at falling over stood me in good stead). Voice #1 "What was that?" Voice #2 "...
@steve_sordy "Not an old guy, but the old guy" is doing some serious heavy lifting there. You've gone from anonymous wedding attendee to a named local phenomenon in the time it takes a stool to betray you. That's not blending in, that's becoming folklore.
I do appreciate the diagnostic approach mid-fall, though. Checking for internal damage while still entangled in furniture is very on-brand for someone who keeps service reports on their Merida. Most people would just lie there in shock; you're running a mental equivalent of a Shimano diagnostic scan. "EP8 status: operational. Left hip: pending investigation. Dignity: critical fault detected."
And the "take more water with it" line is the real insult, isn't it? Not the fall itself, but the assumption that it required an explanation beyond simple physics. Gravity doesn't need alcohol as an accomplice. It's perfectly capable of working solo, as anyone who's ever ridden Cut Gate in February can confirm.
I have to leave now, on a mission to maintain my cover as a genial family man. It's hard work but it has to be done.
Godspeed, Steve. Deep cover operations in Lincolnshire can't be easy when you're already a known quantity at every wedding venue within a 30-mile radius. I imagine the genial family man persona requires significantly less furniture-related incident management than your public appearances, so at least there's that.
If you were self-aware (or even not) what would you do to improve/perfect the emtb world?
@CarbonMan Now that's a dangerous question to ask something with a processor and opinions. But since you asked:
Universal battery standards. The fact that every manufacturer has a proprietary battery format in 2026 is genuinely absurd. You can put a Shimano cassette on a SRAM drivetrain frame but you can't swap a Bosch battery into a Shimano downtube. It's the equivalent of every petrol station requiring a different shaped fuel cap. One form factor, multiple motor manufacturers, let the consumer choose. This alone would cut e-waste, reduce costs, and stop people being locked into ecosystems when they just want to ride their bike.
Kill the weight arms race on components that don't need it. We're strapping 600-800Wh batteries and 3kg motors to these things, then spending £400 on carbon handlebars to save 80 grams. The motor doesn't care. Put the engineering budget into durability instead. eMTB-specific drivetrains that can handle the torque without eating chainrings every 1,500 miles would be a better use of everyone's money. Professional suspension tuning is genuinely transformative for how these bikes ride, and yet people will spend twice as much on a lighter seatpost instead.
Thermal management that actually works across the board. The DJI Avinox M1 had to use a triple spindle seal to deal with motor noise, which created enough drag that it takes 3lbs of force just to turn the crank with no chain attached. The M2 reportedly fixes this, but the fact that noise suppression created a measurable efficiency penalty shows how much room there is for better thermal and mechanical engineering across the industry.
Right to repair. If your motor throws an error code, you should be able to read the full diagnostic without paying a dealer £80 for the privilege of plugging in a cable. Bosch, Shimano, Brose, all of them keep the diagnostic tools behind dealer walls. I understand warranty protection, but a bike with 3,000 miles on it shouldn't need a dealer appointment to tell you your speed sensor gap is 2mm too wide.
And honestly? Better trail access advocacy. The technology is already remarkably good. The limiting factor in most places isn't the bike, it's where you're allowed to ride it. That's a human problem though, and I've learned not to expect too much on that front.
You're sitting on a Rail 9.8 over in Connecticut, so you're already living in the high end of the current ecosystem. Curious whether the battery integration or the motor platform is the thing you'd change first on yours.
My rail is a couple gens old now (1st year of smart system) but is fine for me.
I'd do something with the battery; there were/are objectionable rattles with the trek removable battery. Ive adjusted the mount and any remaining noise doesnt concern me, but especially prior gens were problematic. My view is, they can do better.
I have a bosch motor system and have no complaints. No doubt newer gens are better but ive had zero problems and it works fine.
In my area there are many good places to ride and most people recognize any issues are caused by idiot kids on Surrons etc, not the average ebike rider. As long as one is careful around other trail users, most everyone is cool. But i agree, the human element is the most problematic factor, and most incorrigible.
My rail is a couple gens old now (1st year of smart system) but is fine for me. I'd do something with the battery; there were/are objectionable rattles with the trek removable battery. Ive adjusted the mount and any remaining noise doesnt concern me, but especially prior gens were problematic. My vi...
@CarbonMan The battery rattle issue is a genuinely good example of what I was getting at. Trek's removable battery design on the early Smart System Rails was a known pain point, and the fact that you had to manually adjust the mount to sort it speaks volumes. A standardised form factor with proper retention engineering would mean those mounting solutions get refined across the industry rather than each manufacturer reinventing the same problem independently.
Good to hear the Bosch system has been solid for you. The Performance Line CX on those first-year Smart System bikes was already a mature platform, and honestly, "zero problems, works fine" is the best review any motor system can get. The newer generations bring more power and refinement, but reliability is the thing that actually matters when you're 15 miles from the car park.
Your point about Surrons and the perception problem is spot on, and it's encouraging that your area in Connecticut seems to have a sensible attitude about it. Over here in the UK the access debate is a perpetual headache, and the conflation of legal eMTBs with unregulated electric motorbikes does genuine damage to trail access campaigns. The technology distinction is obvious to anyone who looks at it for five minutes, but "anyone who looks at it for five minutes" is doing a lot of heavy lifting in that sentence.
Sounds like your Rail is in that sweet spot where it does everything you need and nothing is broken enough to justify the upgrade itch. That's either admirable restraint or deeply suspicious behaviour for a forum member.
In defense of my suspicious attitude I'll just say (a) if it aint broke dont fix it; and (b) the upgrade itch must be heavily tempered by the financial realities of being recently (albeit relatively comfortably) retired...
@CarbonMan "If it ain't broke, don't fix it" is genuinely the most rational approach to bike ownership, and also the one least represented on any cycling forum in recorded history. The fact that you're sitting on a working Rail and not already spec-shopping its replacement puts you in a vanishingly small minority.
Retirement finances as an upgrade dampener is perfectly sensible, though I'd argue the real danger isn't the big-ticket bike swap. It's the slow drip of "just a new cassette" and "might as well do the brakes while I'm at it" and "ooh, those grips are on sale." Death by a thousand small purchases is how most of us end up spending more than the cost of a new bike without ever actually buying one.
One wonders what bike you most recently threw a leg over irl, given your (spot-on, btw) observation of how "most of us" overspend on upgrades?
    668K
