Custom - 2025 Pivot Shuttle All Mountain
Rod B.
USA, Orange County Ca.
2025 Pivot Shuttle All Mountain, Pro XO Model
Color: Badlands Brown
Stock XO Pro Website Picture
Stock Specifications:
Over the past 25 years of riding, I know what I want in a bike and how I want my cockpit and suspension setup. I average close to 3,000 miles a year and go through bikes fairly quickly. Unfortunately, most bike manufactuers will not sell just a frame to the rider.
I have a very good relationship with my local bike shop. I purchased the Pivot AM, new for $8,500. My bike shop buys all of my new bike take offs., i.e. fork, shock, brakes, wheels, etc. They also discount price and install, any components that I purchase from the shop to replace the take-offs.
On past bikes, I've used the Rockshox ZEB and Deluxe. Rockshox products are good. Because of my prosthetic ankle, I currently prefer the Fox Grip X2 and Float X2 as I can get a better tuned suspension that won't beat the absolute crap out of my ankle. For this bike build, I was trying to reach a total weight of 49 pounds. I made it, just barely at 49 lbs, 10 ounces. Had I gone with a conventional SRAM Eagle cable shift, I could possibly have reached 48 pounds.
I absolutely love this bike, it does everything well, 90% of the time. I'm giving myself a 10% penalty for bone headed errors which were not the bike's fault.
First Ride Pictures
How it looks now...So much fun....
Much of my riding takes place on very rocky terrain that will absolutely damage the frame if the bike gets laid down on a crash.
Zen & The Art of Motorcycle Maintenance Trails, Saint George Utah
It's been my experience that clear films, such as Ride-Wrap will not hold up to a hard rock strike. I've also tried other types of frame protection i.e., 3M paint protection tape, Helicopter Tape, etc. I still use these films for custom applications where as an example, I want the bike logo to show.
However, for areas where the bike receives a lot of abuse and I'm not worried about looks, i.e. inner chain and seat stays, outside chain and seat stays, I use an extremely robust frame protection that will hold up to hard rock strikes. There is a company on Amazon, "Safe Way Traction", that sells a 'Rubberized Stair Tread" tape. You can buy it in various widths and lengths. I prefer to use the 1 inch x 60 feet roll, which sells for $24. You can do a lot of bikes with 60 feet of tape.
The rubberized, non-grit, stair tread tape is tough, thick, flexible, bends well, adheres well, and can be easily removed and new tape applied if the old tape becomes damaged. The product is easy to trim to any configuration needed. Most importantly, it's a robust frame protection that will hold up to most, but not all, hard rock strikes. If you can get past the black rubber, bed-liner look, I very much recommend the product as frame protection.
I have a large plate of glass and Exacto knife set which I use to cut the material
I will layer the tape side to side, to form a wider area. Depicted is the inside chain stay at the front of the triangle.
My 2022 Levo carbon comp had a matte black finish. My ride shorts would rub on the top tube and buff the matte finish. I applied the tread tape to the top tube and chain/seat strays to protect the paint. The stuff isn't all that pretty, but it gets the job done. After 3,200 hard miles the frame looked like new when I sold the bike.
I hope you enjoyed this post.
Be safe,
Rod
First Ride Pictures
Be safe,
Rod
Beautiful bike! Mexican riders use that traction tape too, good for the desert out here. How does the Pivot compare/contrast to your old Levo? Just curious.
Ride 2d@y,
Cómo estás? I spend a lot of time riding the Saint George, Hurricane, Cedar City, Richfield, Brian Head and Moab areas. I love riding the mesas and rock cawling on the red rock slabs.
I really liked my 2022 Levo, with one small exception that isn't the bike's fault. It was my first full power eBike. I set the bike up for Enduro. I installed a ZEB 170 up front and a 210mm x 55mm Fox Float X2 on the rear. I ran TRP DHR-EVO brakes with a 220mm rotor up front and 203mm on the rear. I ran a Zipp 3Zero Moto single wall rim with Sapim Race spokes and D.T. Swiss 350 hubs as my mullet wheelset.
At the time I owned the Levo, I was recovering from surgery. I had a bad accident in 2019 that destroyed my right ankle. In 2021, I had my lower right ankle fused and my upper ankle replaced with a prosthetic joint. During my recovery period, I needed a bike that was super cushy on the rocks and technical descents. My new right ankle is great, but it tends to hurt when I'm hammering hard over rocks. I had the Levo's suspension tuned so that the air spring curve on both the fork and shock was very forgiving on the top half of compression, and then quickly ramped up on the last third of compression. This was great for my ankle, but tended to give the bike a dead, non flickable feel when boosting it off of small trail kickers. I no longer jump so that was never an issue. It's not the bike's fault, it was what I needed at the time.
When I increased travel to 170mm, this decreased the head tube angle and really up'd the bike's descending qualities. No matter the trail, I had total confidence in the bike's descending capabilities. The bike never felt out of sorts when descending. When you slacken the head tube angle, there's a 'Yin & Yang' thing. A bike will becomes better on descents because the steering slows down, however, the slower steering will also cause you to loose a slight bit of nimbleness on tight and twisty trail. The Levo was always a very good climber.
Mesa riding frequently involves climbing up multiple stacks of rocky ledge. The trick is to hit the first ledge fast and hard, while also lifting the front wheel. The momentum will carry you up and over the first ledge without having to pedal. This avoids a pedal strike. As you clear the first ledge stack, you give the bike a quick half pedal pump and immediately pull up hard on the bars to get the front wheel up and over the second, third and forth stacks of ledge. The Levo did all of this well.
Since the Levo, I've now had two Pivot Shuttle All Mountain bikes. This is my personal opinion.....Don't shoot me folks...But it's the best eBike I've ever ridden. It's a great all around eBike. Enough so, that I bought a second one after I mileaged out the first bike. The Levo is a better descender than the Shuttle AM. However, the Pivot Shuttle has a more "All Around" feel. It's more playful, nimble and flickable. The bike is simply wicked fast and has excellent power and manueverability for those technical and punchy climbs that pop up.
Here's the thing. I never got to ride the Levo with a 160mm fork and suspension tuned to a firmer and more progressive spring curve rate. So I'll never really know how good the Levo might have been. Keep in mind that with my ankle, it was the right tool for the job at the time I owned it. My brother Rich now has my Levo and it has close to 4,000 miles on it. I swapped out the 170mm air spring shaft for a 160mm. My brother loves the Levo.
My brother Rich and I on Guacamole Mesa, Hurricane Utah
National Trail, Phoenix Arizona
Gooseberry Mesa
Grafton Mesa Downhill, Hurricane Utah
I have to be honest here folks...At 66 years old, I walked this section on Grafton. There's no shame in my walking game. My medical and dental plan doesn't pay for facial reconstruction surgery.
Here are some of the trails I've taken my Levo on:
Gooseberry Mesa, Hurricane Utah
Bone Yard, Iron Hills Trail System, Cedar City. The skeleton at the top gives you the finger as you drop in. It's a sign of good luck and happy trails to come. Wahoo!
Bryce Canyon's Thunder Mountain Trail with my buddy on his Niner
Kokopelli Trail System, Fruita Colorado
Brand Trails, Moab Utah
Navajo Rocks Trail System, Moab
Mag 7, Moab Utah
Hymasa Trail System, descending the canyon wall on Captain Ahab
Big Chief, Truckee California
Post Downievile Classic ride and time for a cup of coffee, Downieville California
The Levo has excellent range. Lake Tahoe's Flume and Rim Trail Loop, 33 miles and 3,139 feet of elevation gain. I had 20% left in the bank.
My Wife and I own a vacation home in northern Baja at the resort of Bajamar. When we're there, I like to do a singletrack loop along the ocean. The views are incredible and I might add the post ride Pacifico beverages are also good.
My first eBike, post accident recovery
I tried getting back on my pedal bike post accident recovery. The 18 months of not being able to walk, had destroyed my cardio. One day, I was pedaling up the trail to ride 'The Luge' trail which is located in Orange County. I was about to vomit in the bushes from the max effort and thinking about totally quitting mountain biking. Two guys pedaled past me, they were laughing and talking about sports. My keen powers of obervation noted that they were on eBikes. I so wanted some of the happiness. The next day, I bought a 2021 Orbea Rise M20.
I promptly tore the bike apart to see how it ticked. I then promptly began modifying the bike. I was intoduced to eMTB Forum while looking for information on eBikes.....Wahoo!
Little Creek Mesa, Utah
I have to say, my first ride on my eBike felt illegal...I swear I could feel the hand of an angel pushing me up the trail. So sweet...
I've mostly recovered from my accident. My ankle will never be 100%, but I'm thankful for what I have. Life's hard, you deal with it. My friends have asked why I don't go back to riding a traditional pedal bike. I tell them Conestoga Wagons, Horses and Eight Track tapes used to be a thing....
Absolutely gorgeous bike. Congrats!!
Any reason you didn't go for the Fox 38 fork?
Randycpu,
That's a really good question.
Prior to planning the new bike build, I used a Fox 36 Grip X2 on my previous Pivot Shuttle AM. My tuner (Brandon Olsen, Pro Bike Supply, Newport Beach Ca.) had the fork dialed to perfection. I had zero issues with the fork flexing on drops or when hammering into rocks on mesa step up climbs. Additionally, the suspension tune kept the top end very plush for my ankle and the bottom end stiff. I never had an issue with the fork bottoming out on hard hits.
My previous Pivot had a 625Wh battery. The new Pivot came with an 800Wh battery. I was ultimately trying to keep the weight of the new bike close to the weight of my old pivot. I reasoned that if I stayed with the Fox 36, the savings in fork weight would help offset the weight of the larger 800Wh battery. I've used the Fox 38 on past bikes, it's a great fork. Ultimately, the Fox 36 worked for my situation.
I saw you live in the area of Silicon Valley. My daughter and her family live in Walnut Creek, CA. When I visit the family, I always take my bike with me. Her home is near Shell Ridge Open Space and Mount Diablo State Park.
Mark Twain once said the coldest winter he ever expereinced was summer time in San Francisco. I didn't believe him...On one ride, I decided to ride from Shell Ridge to the top of Mount Diablo and back, a distance of 26 miles. When I left my daughter's house it was a bright and sunny 90 degrees. When I reached the top of Mount Diablo it was 37 degrees. I froze my ass off. I now take a jacket with me when I ride the bay area. I don't care if there's a heat wave happening. I've ridden Camp Tamarancho, Briones, Rockville Hills Regional Park and a few other places while visiting the bay area.
My four year old grandson mountain biking with me at Shell Ridge Open Space
Be safe,
Rod
    Join 43,227
