• Warning!!
    UK Pedelec Law
    Worldwide Laws
Amflow tuning?
MickMTB
Surrey Hills
69 year old tecnophobe here, I got my Amflow PL in august and have done 1000miles on it ,it is my 3rd E-bike,and I am loving it so far. The only tuning I have done is to bump up the power in eco so it is not as grim getting back to the car park when I look down and I have 2 m left and it's 3m left to go.the rest are fine, auto mostly unless my knees are giving me grief. My only problem is the 15mph cut off,which usually happens as I am setting up for a jump, got away it so far,apart from knackering a few back wheels. I just need to know how to get the USA limit of 20 mph,don't need the NZ limit,20 mph where I ride would be fine,If you can't put it on here could you point me in the right direction?prefer the vpn way rather than a different size pick up.
Thanks Mick
Thanks Mick
NZ style is the VPN configuration and probably the easiest to mount/connect but you don't need to ride above 20mp.
Who rides a Lambo 150mph when the speed limit is 60 mph.
Thanks Mick
Both methods are the same - go to the derestricted thread on here to find out how. Choose (set VPN to) USA for 20mph or NZ for 28mph.
I did this last week (EU Bike). I first tried NZ - but two well known VPN's did not manage to spoof the system into NZ. Then I tried Hong Kong. Worked first time. God knows what the top speed is now because in top gear on a flat road I get to around 40kmh and its still going up but I can't spin by legs any faster.
Soy un tecnófobo de 69 años. Compré mi Amflow PL en agosto y recorrió 1600 km con ella. Es mi tercera bicicleta eléctrica y, de momento, me encanta. El único ajuste que le he hecho es subir la potencia en modo ecológico para que no sea tan complicado volver al aparcamiento cuando, al mirar hacia abajo, me quedan 2 my me quedan 3. El resto va bien, casi siempre en automático, a menos que me duelan las rodillas. Mi único problema es el corte de velocidad a 24 km/h, que suele ocurrir cuando me preparo para un salto. De momento, lo consiguió, salvo por un par de golpes en las ruedas traseras. Solo necesito saber cómo conseguir el límite de velocidad de 32 km/h en EE.UU. UU.; no necesito el de Nueva Zelanda; 32 km/h en mi zona estaría bien. Si no puedes ponerlo aquí, ¿podrías indicarme cómo hacerlo? Prefiero usar una VPN en una camioneta de otro tamaño.
Gracias Mick
45kph limit mate - though the rumour was, if you`ve never updated the bike from new, it would be unlimited.
    670K
