What eMTB's are using a 210x55 rear shock?
Like nearly all of them. 205mm Trunnion shocks, with the internal spacers being slightly different for more travel, have became the standard.
I know because I have a custom tuned coil shock of the same dimensions and it was a requirement for me. In fact short of the previous gen Crestline, all e-bikes I've looked at are 205T x 55-65.
210 is a non-trunnion size
Confidently incorrect.
Hardly a 'standard' when a boatload of bikes come with 185mm, 210mm or 230mm. None of which are trunnion, although @jever98 already pointed out your mistake with that assumption.
You must have world’s best ever air…or coil shock if you want to buy bike around the shock, maybe you share what it…or it is?
I took it that the OP has a really nice shock they'd want to move over from another bike. But either way, must be something pretty interesting.
Although unless it's something like a Telum, it'll need a re-tune.
@wb3jma Don't restrict yourself to the exact stroke length!
My previous bike was a Focus Jam2. That had a RockShox Deluxe R Debonair 210x55 shock. I tried to replace it with a DVO Topaz T3, but although they sold 210x55, I just could not get one. Apparently they didn't make them often enough and those that were, sold out immediately. But I could find plenty of 210x50. Then a wizard at one of the DVO stockists told me that I could buy a 210x50 and change the stroke length very easily by changing the spacers. Spacers were available on line to convert the shock. Once I had all the bits and pieces, it took me 15 mins of faffing about reading all the on-line stuff and less then 5 mins to actually do the job. It was a doddle!
Read up to see what the stroke range is on the particular shock you are concerned with.
Doh, my apologies.
I had meds after surgery and straight up confused 210 and 205! A lot of the bikes are now running 205 Trunnions, not 210s! I have a custom tuned coil shock so do look for 205 Trunnion shock mount as a selling point.
It is a shockingly common size on the modern bikes that I looked at including the Transitions, Santa Cruzs, Crestline, Antidote, Norcos & a few others I looked at off the top of my head. It feels like it's becoming a standard size to me just because it's so common on new bikes.
I think the Forbidden's are on the 210mm shocks still.
Sorry OP.
Orbea Rise is 210x55.
As already alluded to though, a lot of shocks these days are physically the same which but use spacers to get the final travel.
Fox/Manitou for example, a 210 shock is a 210 shock. The only difference between 50/52.5/55mm stroke is the spacers. The next size up might be 230 that would come as 60-65.
I get your thinking. You've got a decent shock that's probably better than a lot of the OEM offerings in your budget. I wouldn't personally buy a bike purely to use a shock that I owned.
There are far more important things like motor choice, battery size, intended use etc that should take preference over the shock size.
You might find a bike that's otherwise perfect and maybe in a sale and disregard it just because the shock is 230mm.
Easier and cheaper to use the original shock for a bit and sell the one you've got to buy something better down the line.
It is a shockingly common size on the modern bikes that I looked at including the Transitions, Santa Cruzs, Crestline, Antidote, Norcos & a few others I looked at off the top of my head. ...........
Shockingly common! :ROFLMAO:
a 210x55 is already at the upper limit of possible stroke. You can short stroke it to x52.5 or x50 but your not going to find any eMTB's with shorter strokes to begin with.
a 210x55 is already at the upper limit of possible stroke. You can short stroke it to x52.5 or x50 but your not going to find any eMTB's with shorter strokes to begin with. Also depend son the shock maker and shock easier to do with some than other's.
