The star nut is there so you can preload the upper and lower headset bearings with the top cap pressing stem/spacers to make sure no play in the headset, after that a properly tightened stem does the work of keeping the bars and fork facing the same direction. I'm guessing slightly off center shouldn't affect it.New bike and it seems to me the star nut is crooked. Should I leave as it is or does it need extracting and inserting a new nut? The top cap seems centered when tightened down.
Hopefully it holds. But if it doesn't then life could get VERY 'interesting'PS: Ancient proverb: "Don't fix what isn't broken!"![]()
Another ancient proverb is "A stitch in time saves nine!"Hopefully it holds. But if it doesn't then life could get VERY 'interesting'![]()
Look again. The tabs are bent more on one side that the other.It is difficult to judge from the photograph, because the camera lens was not exactly above the centre of the fork steerer.
As @RustyIron said the star nut is a stamped out piece of junk. There is a gap between the thread in the star nut and the top cap, so any slight misalignment will be easily compensated for. I have tried fitting a star nut without a star nut setting tool and I had to give up. As @RickBullotta said, they are cheap and you will get it installed perfectly every time. It is a fairly safe bet that a setting tool was used originally on your bike.
I agree that they are, but the key thing to look at is whether the centre of the top cap thread is in the centre of the fork steerer and it looks to be very close. As @RustyIron said the star nut is a cheap thing. It doesn't matter how bent it is, it matters whether it is central.Look again. The tabs are bent more on one side that the other.
Knock it through and put a new star nut in with the proper tool. YKIMSAnother ancient proverb is "A stitch in time saves nine!"
Two contradictory pieces of ancient wisdom. What are we suppoosed to do?![]()
It looks centered, but can be off by a mm. It's hard to eyeball. I will probably get around to changing it at one point, I like tinkering around the bike.I agree that they are, but the key thing to look at is whether the centre of the top cap thread is in the centre of the fork steerer and it looks to be very close. As @RustyIron said the star nut is a cheap thing. It doesn't matter how bent it is, it matters whether it is central.
You can see how far off centre it is by hand screwing a bolt loosely into it. Suspect the bolt will be off centre by a surprising amount. Post a pic?It looks centered, but can be off by a mm. It's hard to eyeball. I will probably get around to changing it at one point, I like tinkering around the bike.
If it was me.New bike and it seems to me the star nut is crooked.
This ^^^^…a star nut setting tool is worth it - cheap and you'll get it centered and at the proper depth every time.
This^^^^The star nut is there so you can preload the upper and lower headset bearings
This^^^^ (4-5nm)…torque up the stem
And this^^^^^…my OCD would have to be served by knocking it out the bottom of the steerer tube and fitting a new star nut.
This^^^^…As long as you can install the screw and it doesn't look all crooked
This^^^^…but not expensive (ie dirt cheap)
This ^^^^…Ancient proverb: "Don't fix what isn't broken!"![]()
This ^^^^…errrr…I mean WHAT THE…Another ancient proverb is "A stitch in time saves nine!"
This^^^^Knock it through and put a new star nut in with the proper tool.
This^^^^…live happily ever after.
All you really need to do is knock the old star nut completely out of the bottom of the steerer tube, or at least far enough down so that it doesn't interfere with the new star nut or stem bolt.I ordered new nuts with the tool. Drilling the old nut out and inserting a new one should be pretty straightforward![]()
Don’t driill it. Just drive it out the bottom of the steerer.I ordered new nuts with the tool. Drilling the old nut out and inserting a new one should be pretty straightforward![]()
Interesting.I read conflicting info about that. Some say the steerer is narrower near the bottom.
Who the heck knows, it was some Reddit thread or pinkbike forum.Interesting.
What brand or type of fork would that be?
OkWho the heck knows, it was some Reddit thread or pinkbike forum.
