I’m trying to run similar with the stock gx crankset, but I’m noticing the chainring/chain will actually move backwards when back pedalling (like a normal bike) due to the gx crank’s large plastic “seal” creating a tight fit with the ochain housing… this seems to cause issues with the motor’s clutch, creating a brief grabbing sensation when stopping pedalling (or back-pedalling when ratcheting up a technical climb, for example)… did you have to use different cranks to get around this problem?It is an O-chain, couldn’t find a spider as I run a 32T chainring, I’ve been liking it. Zero pedal kick and don’t notice that it’s there.
Bike is RH-2, running an old 150 dropper. Sram calc says my short butt can only fit a 150 even with the new style.
I’m running Pinnd cranks. Have heard of binding issues with stock cranks.I’m trying to run similar with the stock gx crankset, but I’m noticing the chainring/chain will actually move backwards when back pedalling (like a normal bike) due to the gx crank’s large plastic “seal” creating a tight fit with the ochain housing… this seems to cause issues with the motor’s clutch, creating a brief grabbing sensation when stopping pedalling (or back-pedalling when ratcheting up a technical climb, for example)… did you have to use different cranks to get around this problem?
Right on, appreciate the info!I’m running Pinnd cranks. Have heard of binding issues with stock cranks.
Did you get the 52 or 55mm?It is an O-chain, couldn’t find a spider as I run a 32T chainring, I’ve been liking it. Zero pedal kick and don’t notice that it’s there.
Running the 55mmDid you get the 52 or 55mm?
