- Thread starter
- #31
What's the RX connect app?
The RX Connect App provide some informations as Whaapp is that?
I can only see the tracks that I’ve recorded with app Komoot I don’t know how to record tracks with fitRegarding the APP, I'm using Komoot as well. The past trips are visible in teh FIT E-bike App under saved activities. The trick is that files are not sort by dates, so you need to look at the whole list. Here is how the screen looks like View attachment 172679
The RX Connect App provide some informations as well :
View attachment 172681 View attachment 172682 View attachment 172683
The way I deal with this : I'm planning my trip with Komoot. Then I sync Komoot with Fit App, Then I launch the trip directly on the FIT display on the APP. Track is then recorded in the FIT APP.I can only see the tracks that I’ve recorded with app Komoot I don’t know how to record tracks with fit
Oops, sorry, the RX Connect App is linked to Riese & Muller E-Bike, not to the FIT/Pinion solution. R&M bikes are provided with an Embedded RX GPS/3G ship hidden in the bike, and can deliver informations (like alarms) in case the bike is stollen.Wow. What app is that ?
I miss shimano app.
With shimano I had as well this info of all my tracks No need other apps
Yes ... but not free ! It's free the first year, then you will need to pay 5 € / month to get the bike live localisation + alarm if someone is moving the bike. 25 € / month with insurance on top (Bike stolen and or damaged)....Looks a decent addition - Haibike are you reading.....!!
I have installed a gps tracker device connected to the motor using the light connectorYes ... but not free ! It's free the first year, then you will need to pay 5 € / month to get the bike live localisation + alarm if someone is moving the bike. 25 € / month with insurance on top (Bike stolen and or damaged)....
I'm not satisfied with the FIT App too anyway, so I have added my old Garmin Edge 820 (power supplied by the bike), and later on, will replace it with Iphone on the bar + Komoot + power supplied by the bike as well...
I reply myself, it’s battery level of the phone
are you referring to this piece?make sure that the snubber is set correctly at the rear. If you have too big a gap, you run the risk of snapping a belt.
I've made my own snubbers for my two bikes with stainless steel bearing for this reason
I've altered it slightly since I made this version, but had no issues since.are you referring to this piece?
It’s currently installed very close to the belt, But even in this position, it couldn't prevent the belt from slipping off the sprocket.
Could you post a pic of your piece made on your own ?
Wow. Awesome work !I've altered it slightly since I made this version, but had no issues since.
I had the type in your picture, and it wore flat and started to jump .
I agree App is totally useless , the same as range calculatorOkay, I love Pinion MGU, but the fit app and the display are crap.
Fun fact: If you own a SIGMA bike computer, it can pull all the important info (e.g. how much watts YOU are putting in) from the bike. But the app can't. Also the little display won't show you.
I hope now that Pinion has kind of bought FIT, they will get someone competent behind that.
My Rotwild has a USB C plug on the stem, so I would love to use the FIT app, if it was any good.
A friend of mine has a Sigma, I do not. So I may misremember.I agree App is totally useless , the same as range calculator
How did you connect the bike to sigma ? Can this device make a summary of the assistance modes used and other stats of the trip?
The drive mode of the app is good and show many info. But I can’t believe that it s not possible to record and save a trip and show stats after finishing
Also I wonder why this info couldn’t be displayed in the onboard display of the bike
I don’t have good expectations about the future with pinion
Before i buy the bike I requested them some tech info about the bike and I never got an answer from them
I cross finger anyway
Mine only have 3 months.It id due the 12 month oil change.
the bike shop can disable the service message.
