Wish Bosch would enable Apple Watch to be Kiox key!
Alfmeister
Uk
I really wish Bosch would allow the Apple Watch to be used as a key for unlocking the bike in the flow app. It would make alot of sense, no retrieving your phone from your back pack, just a quick slip on you watch, and away you go. I know you can set the lock up to Auto Unlock when your phone is close to the bike, but that’s not good for security in my eyes, as it’s a proximity function, which means you bike could be unlocked, when you’re not actually next to it.
Agreed, excellent idea Alfmeister 👍🏻
And I think in todays criminal infested world, it should only unlock when within 1 metre proximity. And while we're at it, a hi-jacking feature would be nice to stop the balaclava clad, stabby type crims, who terrorise society and cyclist with threats of violence and physical harm with a knife or hammer.
A sram axs type auto spike through the seat 😉🤔😎. Doesn't need to be sharp, just protrude up through the seat so the little scrotes can't sit Down for a long time after 😉😵‍💫.
Not an owner of an Apple watch so no idea how it functions but is it not also a proximity device?
I presume he meant that you could hold the watch against a particular bit of the bike (controller/remote?) like an RFID card to unlock it/lock it?
Mind you, that could be done on a phone as well, Bosch would have to put a reader somewhere on the system for that to work though, otherwise it is indeed a proximity device the same as already implemented on phones.
I don’t have an Apple Watch either, but as it works on a phone already then it should be easy to implement via the watch. I’m not an App developer though so there might be a good technical reason.
The flow app allows either proximity or swipe within in app, I prefer the swipe in app, as I think it make the bike more secure. The proximity solution is a worry when you are maybe having a break, maybe sat away from the bike, but close enough that the alarm lock has been deactivated.
I think the only way is to retro-engineer the communcations battery/motor/controller and do it by ourselves. Everything encoded.
My concern is you're not sat right next to the bike, but close enough to disable the bosch lock/alarm unknowingly. The solution is to stand/sit far enough away it won't be close enough to disable the lock/alarm, but then you're too far away to react quickly if a scrote decides to nick it.
first world problem, but unfortunately there are enough undesirables out there looking to get their next fix or hit their weekly targets 😉.
I don't really want to have my watch taken at knife point too.. so errr no thanks :oops:
If they knew you were wearing kelvin kliens they'd take those at knife point too. Quite frankly todays thief will nick just about anything thats worth something on the black market.
