Spectral:on fork (and rear brake) change
JiiPee82
Finland
I bought 2023 Spectral:on and will get it in few days.
I have Zeb ultimate, with 175mm steerer tube. Is it too short for spectral:on?
I want to replace DB8 brakes with Shimano XT brakes. What I have to remove to get rear brake hose changed?
I bought 2023 Spectral:eek:n and will get it in few days.
I have Zeb ultimate, with 175mm steerer tube. Is it too short for spectral:eek:n?
I just changed the levers to Shimano on my db8 brakes, more powerful than straight Shimano setup
according to Canyon's geometry chart...
Head Tube Length in mm (d)
S 115mm
M 125mm
L 135mm
XL 145mm
so your Zeb's should be compatable with all except the XL as it would have ~30mm of steerer tube exposed for the stem to clamp on before you tried anyspacers?
S 115mm
M 125mm
L 135mm
XL 145mm
The part which have cable routings and canyon stem looked massive in pictures, so doubt how many mm they would take.
Are they compatible? Just shimano insert to brake hose? What oil did you use?
Yes just changed lever end to Shimano olive and barb, both use mineral oil, I just topped up with some Magura fluid that I had, no issues at all.
I find this setup more powerful than the full Shimano systems that I have on other bikes.
I changed to Shimano XT brakes on my spectral on, and the rear caliper has a banjo bolt and I needed to drop the motor to route the brake line.
