Urrun (M) dropper diameter, travel & over all length?
BAh30
Alameda, Ca USA
I have a kemen suv ebike and want to install a dropper but cant find the overall length, diameter and over all length for the medium frame info from the blue paper. So im hoping with the same info from the urrun i can piece together what i need.
I have an XL Urrun and installed a dropper post. I'm pretty sure it was a 200mm PNW Loam. They (and most manufacturers) have a calculator.
Hope this helps:
Hope this helps:
Thanks. Only thing ive found specific to the kemen is max insertion is 270mm for the medium frame. Im assuming this is from the collar to the charging port in the seat tube. So i think i can use that and add it to my existing saddle height from the collar to the saddle to determine the overall length of the dropper ill need.
Ok. So this is my first rodeo doing this much extensive work on a ebike. Dropped the motor. Disconnected every thing. The dropper install was easy. It was Reassembling the internal cables thru the headset and stem and getting the motor to fit in the frame with all the internal wiring sucked. Made me think of unserviceable the cable routing is. Wondered about drilling downtube ports like on my rise...
