I have noticed when I leave the bike at the evening and pick it up in the morning battery is always down 3-4% no matter how full it was and I doubt "Find My" draw that much battery
Never happened with G3.
Here's what I understood.
The cause is the recalibration of the battery cells.
Recalibration consists (as far as I know) in discharging the cells with a higher voltage to bring all cells to the level of the one with the lowest voltage; in this way a subsequent recharge may bring all the cells to the maximum voltage.
This because, to preserve the cells, the charge is interrupted when a cell has reached the maximum permitted voltage and therefore the charge is interrupted for all the cells, even for those that would require a further charge.
It seems to me that in previous models as TL G3 the recalibration process took place in the final charging phase, in fact it took a long time to finish.
Instead in G4 the charging process ends as soon as it reaches 100% .
This is possible because the recalibration has already been done.
Regarding this topic you can find this in User Manual:
13.16.3 STATE OF CHARGE AT START UP
When turning on the bicycle, the SOC shown on the display or in the app may differ from the value displayed before powering the bicycle off. This may be caused by battery recalibration when the bicycle is powered off.
The manual does not say how long after the turn off of the bike the recalibration process takes place;
I noticed that it never happened in stops during a ride
