Only thing that I wish the Amflow had.180/170 travel bike.
Yes it isn't. I said it was more suited to Enduro compared with the Amflow.Vala isn't enduro
Yeah. But then it wouldn't be as playful. I love how playful it is. That's why I'd probably just add a longer travel EMTB to my stable, as I get better.Only thing that I wish the Amflow had.
See this is what worries me. To use an example, does the Amflow end up being more like the Fuel EXE than the Rail? For me a 150mm bike needs to be a capable 150mm.Yes it isn't. I said it was more suited to Enduro compared with the Amflow.
My mate has a Fuel EXE. The Amflow will be very much like the Trek, but on steroids. He is a better rider than me, but I can climb some technical routes he just cannot clear. And it's not just the power. It's the traction control like power delivery of the Avinox motor, because it has a 42 point sensor on the rear wheel, compared with the single sensor on the Bosch. Sampling what your rear wheel is doing 42 times per revolution, compared with once, vastly reduces tyre slip. Especially if it's greasy.To use an example, does the Amflow end up being more like the Fuel EXE than the Rail?
Fast flowy downhill, to tight technical steep trails. I can ride to the American river and Salmon falls and Olmstead loop from my house
Downieville Downhill
Downieville Downhill is a singletrack mountain bike trail in Downieville, California. View maps, videos, photos, and reviews of Downieville Downhill bike trail in Downieville.www.singletracks.com
Hoot Trail
Hoot Trail is a singletrack mountain bike trail in Nevada City, California. View maps, videos, photos, and reviews of Hoot Trail bike trail in Nevada City.www.singletracks.com
American River Confluence Trails
American River Confluence Trails is a singletrack mountain bike trail in Auburn, California. View maps, videos, photos, and reviews of American River Confluence Trails bike trail in Auburn.www.singletracks.com
Salmon Falls
Salmon Falls is a singletrack mountain bike trail in Folsom, California. View maps, videos, photos, and reviews of Salmon Falls bike trail in Folsom.www.singletracks.com
Olmstead Loop
Olmstead Loop is a singletrack mountain bike trail in Cool, California. View maps, videos, photos, and reviews of Olmstead Loop bike trail in Cool.www.singletracks.com
It's interesting doing the stats comparison, the Bosch kit with the smaller battery is indeed lighter than the Amflow at 800wh. Components are components, same shiz per performance, so unless I'm missing something if the Amflow still ends up lighter with the same (my favourite) components, it's frame material. I dunno, I think I like the idea of more frame material generally on a bike I want to ride the crap out of for years.
And here is comparing like for like on the batt, both 600Wh. Up to 500g in it.
Listen. The circumference of a 29er wheel is over 2 metres. I've spent 30 years in the Drive Control Industry. No one can control a motor precisely getting one speed reference every 2 metres. The lag in the feedback loop would just be too large. Sure you use current draw as the wheel looses traction. But current takes time to build and fall in a motor, unlike the instant feedback of a speed sensor.Bosch (and other motors) implement traction control in a different way, they don’t need the 42 point sensor ring, otherwise they’d have one.
There is a reason they use speed sensors when trying to do Anti-Lock braking. Response from any other factor would be too slow.
Pedal Pressure, candence, and torque input, is what the rider puts in. It doesn't help the motor control slip, like a speed sensor, unless the rider changes these inputs. Meanwhile a speed sensor can reduce slip without the rider changing his inputs. That's the point of it. That's why I install speed sensors on drive installations with varying loads. If load doesn't vary. You don't need them, because slip remains constant.I literally just explained how other sensors are part of the system, pedal pressure, cadence, torque input, it doesn’t rely on the speed sensor.
We agree here. Bosch do it by measuring current and voltage. But this is much slower responding than a speed sensor. As I explained. Current and voltage takes time to rise and fall in a motor, due to induced currents and voltages created by a rotating motor.It’s just wrong to say the Bosch only does traction control from the rear wheel speed sensor, it doesn’t, as I’ve explained.
I have actually never thought "I need traction control" on an ebike. I've sometimes thought "Oh I fucked up my weight distribution and spun out".Ride a Bosch motor bike for any length of time and then you’d know it works. Jeez.
We agree here. Bosch do it by measuring current and volage. But this is much slower responding than a speed sensor. As I explained. Current and voltage takes time to rise and fall in a motor, due to induced currents and voltages created by a rotating motor.
Yeah. And that was kind of my point, the Amflow is being touted as hugely lightweight full power bike but if the frame and spec was burly there wouldn't be THAT much in it. As we see with the Druid, it seems.With weights that close, I wouldn’t be choosing based on that alone.
I dunno, all this traction control talk, next minute it'll be ABS (I know, it already has... smh).
Yes it is inferior. A speed sensor or encoder is used in industry when you want precise control of a varying load. If you are trying to suggest that you can do it better without speed feedback, then it's pointless having this conversation. That is the entire point of a speed sensor or encoder.The Bosch system isn’t inferior though, far from it.
Bosch have developed ABS for MTBs. Fox and Rock Shox have developed electronic smart forks and shocks. It's where mountain biking is moving.I dunno, all this traction control talk, next minute it'll be ABS (I know, it already has... smh).
This is your problem. You see everything as right and wrong. Bosch isn't doing traction control wrong. Avinox is just using motor control technology to do it better. Reducing feedback lag time will always produce a better control loop. If you cannot agree with this fact. Then I don't see the point discussing further.I presume you’ve emailed Bosch and told them they’re doing it all wrong?![]()
Great. Continue to use the lesser product. I'm choosing to use the greater product. Both are certified as EU compliant. And that's all I'm concerned with.At some point though, mountain biking will become off road motorcycling, and that’s not what I’m interested in, otherwise I’d do it (again) already.
I bet this post showing how much better the DJI climbs, compared to the Bosch CX, must be driving you nuts .......
"As I stated earlier, there’s a technical hill climb (down hill for mtb) that I was not able to quite conquer with my previous Bosch Race Crestline. (Around ten previous attempts in 1st and 2nd gear)
My FIRST attempt this morning with the RS181 I nailed it in 3rd gear!!! All the way up without taking a foot off the pedals, in Turbo mode."
Crestline x DJI - RS 181 SPECTRE Edition
I have both and maybe can shed some light. I live near Bellingham where these bikes were conceived and met both owners. My Regulator CX is now 160/170 with vivid coil. I upgraded the dropper to 210 from 180. With all these upgrades, this bike is super dialed and on the same level as the...www.emtbforums.com
Mate. It's an Amflow thread. And I'm talking about Amflows. You don't see me stalking the Bosch threads, trying to push Amflow ? How's your record ???I don’t see any point discussing it further either, you’re a forum hammer and any post not praising Amflow to the hilt is a nail…
Been rainy and rubbish here. Ride with the boys got cancelled. That's why I'm on here so much. What about you ?You’re just trolling now, enjoy what’s left of your weekend.
No, ABS is not like analog vs MTB at all. Or traction control.Bosch have developed ABS for MTBs. Fox and Rock Shox have developed electronic smart forks and shocks. It's where mountain biking is moving.
And just like all innovation. The old school don't like it. A bit like the MTB purists who don't like our EMTBs and say they are not cycling.
