New chain flapping making noise
james4555
Sheffield
Just got my bike back from the lbs and the chain is flapping near the chainring.
Video of it happening below
Had a new chain and cassette fitted.
It's either he has fitted the wrong chain, which is a narrower chain, like a 12 speed chain. Thus it's grabbing the chainring teeth too tight. Or the chainring is too small. It's not releasing the chain. You cannot have a big tooth, small tooth chainring on a chainring that small. It can't release the chain cleanly.
The bike is a Cube Reaction Hybrid CUBE PRODUCT ARCHIVE | Reaction Hybrid SL 500 black edition 2018
think it's the same chain as the old one KMC X11 is there different versions of that chain
Parts look correct. But the chain is not releasing off the chainring cleanly.
I don't know. Does the derailleur have a clutch ? Is it turned on ?
Thought so I did ask them to put a new one on but he said it was ok. The rear mech is flapping as well do you think changing that would also help.
If you've changed the chain and cassette it can only be the chainring, probably the teeth are worn and won't release the chain cleanly
see attached photo from another post
thanks ill give it a try
I really can’t tell, or don’t know, if your chainring has narrow/wide cogs. If it does then the narrow chain link may be on a wide chainring cog. Moving, or jumping the link one position over the chaining may solve the issue. (It’s easy to happen when a new chaining or chain is installed. Your chain may behave as shown in your video. (Like chain suck)(A narrow link is trying to fit over a wide chainring cog).
Maybe that’ll help 🤷🏼‍♂️
Just done a measure of the chainring with some callipers
it's a 15 teeth chainring and it's 65mm wide. The teeth are 4mm wide at the top and the gap between each teeth is 10mm at the top.
The spacing between the rollers of the chain is 5mm and 5.3mm and the width is 4mm and 2mm20250705_202018.jpg
Hope that helps.
I'd imagine a 15t chainring (15t, that's tiny) wouldn't last long before being totally shagged out, and it's going to eat chains for breakfast being such a tight radius.
What chainring do you recommend to use that's compatible with the KMC X11 chain ? i use the bike for commuting to work and a few TPT trails around South Yorkshire.
I don't know you bikes motor, if that chainring is standard fitment I'd guess it was designed that way? Did it ride OK before the new chain and cassette? If so replace the chainring. Also does the derailleur have noticeable tension when pulled forward towards the front wheel (I don't think yours has a clutch)? If not that could also be the problem. It (the derailleur) should have strong spring tension to take up the slack when in the smallest rear sprockets on the cassette.
My old bike with a Gen 3 Bosch CX motor also had a 15t chainring I sold it after 4 years use and over 4k Km still with the original chain, chainring and cassette never had any problems with it! I would imagine modern chains are more than able to handle such a tight radius even those even tighter top gear 11t ones on the cassette!🤨
Are you taking the piss?
The spacing between the rollers of the chain is 5mm and 5.3mm and the width is 4mm and 2mmView attachment 163698
Hope that helps.
I can see what I think is the problem. Your chainwheel teeth are not of the narrow-wide variety, and they look all wide. Which means you are getting chain sucking to the chainwheel on every second link.
I just measured my narrow-wide chainring. The chainring teeth thickness at the bottom of the teeth is 1.9mm at narrow teeth, and 3.6mm at the wide. It looks like all your chainwheel teeth are about 3.5mm thick.
The only way to explain this is if the LBS bought a new chainring, but it was the wrong type. Or the original chain was wider.
Anyway. If you have a vernier. See if you can measure the chainwheel thickness at the bottom of each teeth. If all the teeth are about 3.5mm. It's a problem.
Maybe a little, sorry, but the 15t chainring with a 11t to 42t cassette was a typical setup on the old 75nm Bosch CX motors so suggesting it would be the cause of very rapid chain wear is certainly not my experience and seemed worthy of some doubt casting!
Both my posts here are off subject anyway and little help for the OP, hope the other posts help get the problem fixed.
Done a measure and the thickness on the chainring of all the teeth at the bottom is 2mm. The previous chain was a Shimano one. Would they have installed a chainring that would only work with Shimano and not a KMC chain.
This might not be any help whatsoever, but there's probably more fake KMC chains in the world than genuine ones. Even the plastic box packaging looks exactly the same. If somethings wrong, take it back to the lbs who you paid to sort it out.
Have done twice and both times they claim to have sorted it even said they test rode it but still happening. Booked it into another lbs i've used in the past see what they think fresh pair of eyes. Will point out what's been suggested here learnt a lot and thanks for all the help and suggestions.
Then maybe try a 11S Shimano Chain. It would only be about 20 pound.
That does seem correct for a Narrow only chainring.
Tried a brand new shimano chain today still the same. Will try a new derailleur next and also a new chainring on the way so hopefully one will work.
I'm beginning to think there is something else going on. Before you start replacing all the parts, as this can get expensive, and may not solve it. I would get a good bike mechanic to look at it.
