Level 2025?
Mine is announced for s23 (june) ... i hope so !
Only R models. RR & XR in September/October
180/170 with mx wheels e13/zeb select/vivid coil base/maven bronze/bosch gen5 800wh/ sram eagle 90
But, MX only or also 29/29? :mad:
Only Alu or also Carbon?
Weight?
My dealer says he has something to "show" me. Cant wait. I think the same fantastic rear end as the Dune/crafty carbon. Coil shock. alu frame makes for a lower price than the crafty carbon in R build he says
That's it. Only R model, vivid coil zeb select maven bronze and eagle 90. Flame red and black 😍
Is actually the Bosch Kiox 400 also compatible with the Mondraker Level R because its the only one without it and seems to be that the cutout on the upper tube is just for the normal controller?
Finally 😍
And no, not kiox 400 compatible.
First batch of frame, rr and xr will bé aviable in september
Sadly they didn't applied the same recepy as with the Crafy with a carbon front triangle. Honestly, at 26-27 kgs it's really heavy.
2 positives
we non dentist might afford it
weight gives traction. Stability and better suspension performance. Just what we need from a semi DH coil ebike. I love it. 180mm in the back would be better but having tested the crafty carbon with the same awesome rear end all is good in my book. This looks like a rocket ship :)
What I find strange is it's head tube angle, only 0.5 degree slacker than Crafty carbon, I was expecting at least 1 degree.
2 positives
I've bought my Crafty R at 5700 euros în February. Starting prices for the Level are really similar to the Crafty models ( the RR is very similar but the Level is a bit lower spec)
The Geometry indeed is a bit strange, the Level is only 0.1 degree slacker than a Crafty at with 170 mm Ohlins fork
Mine with 170 mm Zeb is even slacker due to taller axle to crown height.
Also the BB it's the same height, even though it's mullet, hence a smaller drop so for anyone aiming for a plough machine it will not feel as deep feeling inside the bike.
But with higher reach and higher stack.
With the 38mm rise handlebar, you're not too high on the bike.
Finally 😍
That saddle looks uncomfortable… 😂
When you look at this bike, and the earlier ones, it’s got the Cesar Rojo design language all over it. Did he design it before he left?
