You’ll be blown away. The gold 35 sucks balls. No offence. Anything will be an improvementI think it will feel like a huge improvement over the Gold RL.
What did you decide for travel 160mm ?Going to hopefully get the Yari debonair with its new charger 2.1 RCT3 fitted this weekend. I know the RC2 is probably the better upgrade but I got the RCT3 off a mate for next to nothing. I think it will feel like a huge improvement over the Gold RL.
Total upgrade (including sale of the old fork) was £150 which I feel should be money well spent.
Shout out to TF Tuned for the oil
Kit and sending me a couple of new crush washers from the workshop as they are not sold separately.
Should admin just delete this... ?From Simon on the EXe owners page on Facebook
I've come across some unconfirmed rumors about the new Trek EXe model:
• Battery: Main models get a 580Wh battery. Cheaper versions get 360Wh, but can be upgraded to 580Wh.
• Frame: Looks similar to Trek Slash E but without high pivot. Carbon frame only—no headset angle adjust like the current alloy version.
• Sizing: XXL frame size will be added.
• Suspension: 160mm front travel. Some models will use a new Fox shock, not yet released—visually similar to the Specialized Genie shock.
• Motor: New TQ motor with 60Nm torque. Same size/weight as current 50Nm motor.
• Backwards compatibility: New 60Nm motor can fit current EXE frames. Just needs a firmware update. Same battery life expected. No confirmation if Trek/TQ will sell it as an upgrade.
Can anybody confirm or deny?
If it gets deleted then it would just confirm that there's some correct info in there.Should admin just delete this... ?
The current 580wh won’t fit in an Exe and I doubt the newer battery will fit older exes either. Just my thoughts anywayNot fussed about the motor but really hope the bigger battery is backwards compatible.
Why delete it?Should admin just delete this... ?
Rumors should go to rumors thread.Why delete it?
I sure hope they don’t change the frame for the larger battery downtube. The beauty of the EXe is that’s is stealth. If anything, I would hope they went smaller on the downtube. The Slash is to big. I am ok with the 50nm motor, it’s more than enough power for me.From Simon on the EXe owners page on Facebook
I have my 2023 set up for XC. I am a bigger guy at 230 pounds. I only use ECO mode, I have my power turned down to 95% and my assist turned down to 100%. I am in Southern California, Orange county the trails have elevation changes throughout In a 25 mile ride, I will ascend 2500 feet. With this setup, I can only get 28 miles from the Battery. I am doing a 50 mile ride next fall, and plan to swap the main battery at half way.I am sure there are many endurance riders or riders that do longer rides/races.
I am wondering, if riding properly setup Fuel EXE, lightest custom edition, basically same build as your race XC bike just with extra motor and battery but WITHOUT range extender; if this e-bike would be helpful to finish say 100 mile race (or 62mile ~ 100km) easier than the analog bike... say SM100 race.
* Analog bike - 120mm travel fork, carbon wheels- endurance build... max 24lb
* Fuel Exe with same lightweight wheelset and tires, 150mm lighweight build mostly carbon- at say 34 lb
Let's say finish time is not as important.
So I wonder if e-bike here would be a help in this quest or there is no way this bike could last the duration of the race even if assistance used sporadically.
Assume finish time/ riding time 9h.
Has anyone setup/ used Fuel EXE that way?
I just ordered the 50rise from PNW yesterday. Might be a return in my immediate future, I’d prefer the OneUp brand. I’m curious, has anyone installed the V2 E-bike bar with the power wire through the bar on the EXe?OneUp V2 bar is out. They added 50mm rise and a dedicated 760mm bar.
What makes you think that this is a click bait? There's not even a link to click ...Rumors should go to rumors thread.
It sounds a click bait...
1200$ for color only makes no sense. You can upgrade major components for that kind of money.Getting closer to pulling the trigger on a 9.7 with the current sale prices. LBS is selling the 2024 model of the 9.7 for about $1200 more than the 2023 model.
Would there be any reason to go for the more expensive 2024 model of the 9.7? Both bikes have the same spec, looks like the only difference is colour.
Thanks everyone for all the posts so far, this thread has been super helpful.
Don’t do it, motor is feeble and battery is inadequate.Getting closer to pulling the trigger on a 9.7 with the current sale prices. LBS is selling the 2024 model of the 9.7 for about $1200 more than the 2023 model.
100% agree, would never spend that much just for a colour change.1200$ for color only makes no sense. You can upgrade major components for that kind of money.
