Help choosing my girlfriend's first emtb
Zayd Proctor
Italy
Having built my first emtb, I now need to get one for my girlfriend who, like me, is new to both emtb and mtb. I was thinking something used, under 3000€. Entry level components will do just fine.
I think the most important thing here is the choice of motor. Ideally, I'd go with the Bafang M510 because it works with custom batteries, it's serviceable, it can be derestricted, it's easy to upgrade to the M560 if needed.
The problem is that there aren't many offerings with that motor. The best I could find is this refurbished Berria Mako for 3100€.
I have no idea how the other motors compare with Bafang. This is where I need your help. What would you choose?
Here's a comparison of the main mid-drive motors for eMTBs, covering their pros and cons to help you choose the best one for your needs.
🔧 BAFANG (M500, M600, M620)
💡 Best for: Custom builds, high power, DIY enthusiasts
✅ Pros:
✔ High power & torque (M620: 160Nm, M600: 120Nm)
✔ Open system → works with aftermarket batteries
✔ Customizable via third-party apps & programming
✔ Easy to repair with widely available parts
✔ Affordable compared to premium brands
❌ Cons:
✘ Less refined power delivery, can feel jerky
✘ Noisy at high torque levels
✘ Can overheat under sustained load
✘ Heavier than Bosch/Shimano motors
⚙ BOSCH (Performance Line CX, Smart System)
💡 Best for: Reliability, smooth power delivery, premium eMTBs
✅ Pros:
✔ Excellent power curve & natural feel
✔ High reliability & premium build quality
✔ Strong dealer support & service network
✔ Smooth integration with eMTB components (ABS, Kiox, etc.)
✔ Good battery efficiency
❌ Cons:
✘ Requires proprietary batteries
✘ Firmware locked, no DIY tuning
✘ Expensive motor & parts
✘ Some overheating issues on long climbs
🔵 SHIMANO (EP8, E8000, E7000)
💡 Best for: Lightweight builds, natural pedal feel
✅ Pros:
✔ Lightest mid-drive motor (~2.6kg for EP8)
✔ Smooth, natural pedal assist
✔ Compact design with good ground clearance
✔ Efficient power usage for longer rides
✔ Works well with standard MTB drivetrains
❌ Cons:
✘ Less torque than Bosch/Bafang (EP8: 85Nm)
✘ Can overheat under heavy loads
✘ Sensitive to firmware updates that may reduce performance
✘ Limited aftermarket tuning options
🔴 BROSE (Drive S Mag, Drive T, Specialized Turbo Levo/Kenevo)
💡 Best for: Quiet operation, premium feel, integrated eMTBs (Specialized, Rotwild, etc.)
✅ Pros:
✔ Smoothest & quietest motor in the market
✔ High torque (90Nm) with natural power delivery
✔ Compact & lightweight (~2.9kg)
✔ Good integration with premium brands (Specialized, Rotwild)
✔ No resistance when pedaling without power
❌ Cons:
✘ Brose motors have had reliability issues (belt failures, water ingress)
✘ Proprietary system → harder to repair or customize
✘ Limited third-party support & expensive replacement parts
✘ Specialized versions locked to their ecosystem
🟡 YAMAHA (PW-X3, PWseries S2, PW-X2)
💡 Best for: Power & durability, alternative to Bosch/Shimano
✅ Pros:
✔ Strong torque (PW-X3: 85Nm)
✔ Reliable and robust build (good for long-term use)
✔ Works with both proprietary & third-party batteries in some cases
✔ Responsive motor engagement (good for technical trails)
✔ Less software restriction compared to Bosch/Shimano
❌ Cons:
✘ Heavier than Shimano/Brose (~3.1kg)
✘ Power delivery less refined than Bosch/Shimano
✘ Fewer eMTB brand integrations compared to Bosch/Shimano
✘ Aftermarket tuning options are limited
🏆 Which One to Choose?
MotorBest ForTorque (Nm)Weight (kg)CustomizationBattery FlexibilityReliability
Bafang M600/M620Power & DIY120-1603.6-5.3🔧 High🔓 Open⚠️ Moderate
Bosch CXAll-round performance852.9🔒 Locked🔒 Proprietary✅ High
Shimano EP8Lightweight, smooth ride852.6🔒 Limited🔒 Proprietary⚠️ Can overheat
Brose S MagQuiet, premium feel902.9🔒 Locked🔒 Proprietary⚠️ Past reliability issues
Yamaha PW-X3Durability & power853.1🔒 Limited🔓 Semi-open✅ High
🏁 Final Thoughts
  • If you want customization & repairability: Bafang 🔧
  • If you want premium reliability & smooth ride: Bosch or Brose 🏆
  • If you prefer lightweight & efficiency: Shimano EP8 🚵‍♂️
  • If you need durability & power: Yamaha 💪
Which motor are you considering? 🚀
Try your best to buy locally (LBS). You’ll eventually need their support. Also support a few items from them such as helmets, gloves, pedals, grips etc.
There’s 5 or 6 major brands out there. They all have reality decent motors. All of us here could persuade you to a certain manufacturer …but which one is best? It might be easier for me to choose my favourite child.
To which I would add that as you get into it the demands you make of your bikes will probably increase (a lot!) so buying more capable bikes than you think you now need will probably be a good move.
get an orbea rise. new batteries are still available for very cheap on ebay (250 usd or so). In addition, the way the motor applies power will be important as she likely doesn't weigh a ton. When you're 200lbs, subtle and sophisticated power application isn't a big deal, it's a real big deal when you're 120-140lbs.
Lol. Maybe I should tell you what I care about the most so we can find a good fit:
1. Non proprietary batteries or cheap proprietary batteries.
2. Good power delivery
3. Repairability or high reliability or both
Nice to have:
1. Quiet
2. Customizable
Things that matter less: power, weight.
As well as your list, what does she care about/want from a bike?
I know everybody is different but is bike weight an issue if it needs lifting over trail obstacles etc?
It would be advisable to try as many different models as possible to ensure that she can find one that ‘fits’ her best (it’s likely to be different to what fits you) and then try and find one used?
I’d second the find one supportable by your local bike shop as well, unless you’re going to keep spare motors and batteries ready for if they go wrong.
She is completely new to this, she doesn't have any specific needs at the moment. We rented two Trek Rail last summer and she liked it. But pretty much anything would do. Something not too heavy would be preferable.
I seriously overestimated my wife’s ability one day. She had heard my numerous stories and saw my pics of our MTB trails on our mountain.
After riding the tame trails and flats available in our area with her, I decided to show her my playground one day.
This was a huge mistake on my part. What was I thinking? 🤔. We both took our Bosch powered hardtail Powerfly’s and I turned into a black/double black trail. I thought the beauty of the area would make her happy. Was I ever wrong. She left her bike at the top of a long decent and slid down on her bum. Her eyes had swelled up with tears and she could barely talk when we met at the bottom. I can’t remember feeling this bad.
The remainder of the trail was, sometimes, a slow go with the occasional dismount.
She still uses her hardtail for the tame trail network in our area. 40-60km trips are fun for both of us.
I’ve since parted with my HT and purchased a full suspension Fuel EXE (TQ motor). This has leveled the playing field between us. She uses and likes the “ladies” saddle on her HT now.
She also likes the speed of the HT and probably doesn’t need a full suspension. Her bike is a small, Bosch Gen4 CX HT Powerfly. The power is the same as my Rail but she can be much faster (32kmph limit), because of the lighter weight and suitable tires.
So she's complete new to this.
If she's young and not too heavy, there's really no need to buy a full suspension.
A hardtail with branded basic parts can be found new form 2200 euro (Decathlon e-st900) to 2500 euro (Cube reaction 625)
Buy a used SL emtb. Trying to get your g/f into biking will most likely lead to frustration on both sides as you try to push her to do more and her fear and different priorities don't align with yours. If she has friends to ride with as well, that would be the best place to get her interested in riding more and at a higher, level where it's worth spending a pile of money on a fancy bike.
… as you try to push her to do more and her fear and different priorities don't align with yours.
Yup…found that out the hard-way once.
A full powered Hard Tail suits her well. Colour was important and a nice ladies saddle. She trusted me on everything else.
Our trails here are mostly black diamond …but there are a few blue and green level trails. The trails in our neighborhood and municipal parks are definitely green. She likes those.
✅ Pros:
❌ Cons:
✅ Pros:
❌ Cons:
✅ Pros:
❌ Cons:
✅ Pros:
❌ Cons:
✅ Pros:
❌ Cons:
🏁 Final Thoughts
I take it that your girlfriend doesn't have an opinion of what she'd actually like.
Check out the Giant Liv bikes. They are made specifically for women and have geometries for woman. They have models that are the "equivalent" of the Giant Stance and Trance EMTB's but are built for women in terms of geometries. They have similar motors, batteries, shifters, brakes, etc.... They also have a "guide" section which has introduction to MTB and Biking articles written by woman for women which may be helpful. Here is the website: Liv Cycling
W
✅ Pros:
❌ Cons:
✅ Pros:
❌ Cons:
✅ Pros:
❌ Cons:
✅ Pros:
❌ Cons:
✅ Pros:
❌ Cons:
🏁 Final Thoughts
Whatever you get her, make sure she can (barely) outrun you if she tries hard enough... ;) You might also consider getting the same brand motor as you have; same ecosystem might help simplify things.
Since you're familiar with Bafang and building, i'd go with the LCE930 w/ the m820 motor. That thing rips. lighter, slimmer. covers a ton of ground. Plenty of power for uphill, etc etc. I ride pretty gnarly stuff and it handles everything.
Otherwise, my gal has the new Salsa Moraine (Fazua motor). motor is silent and has worked flawlessly for 6 months.
Years ago, I persuaded my now wife to come out cycling with me, to see how I spent my time and of course show her how awesome I was on a bike.
She kicked my arse, and that hasn’t changed with the advent of e-bikes.
We don’t ride together much now, I just slow her down!
Get your violins out please guys. 😂
Just turn your assistance up. Rocket science. Not. ;)
Not mentioned yet is colour and how it looks - must be attractive.
She said that she doesn't really care. Of course, she will have the last word and veto power.
She complained a lot about her bum hurting when we rode for the first time. And she is ready to spend a lot of money on a comfortable saddle. She wants the bike to be as comfortable as possible.
This sounds great, but there aren't a lot of offerings on the used market and the new ones are out of budget.
W
Not gonna happen. I'm getting the M560 for myself. :devilish:
I would like to, but she wants to keep it under 3000€. Closer to 2500€ if possible. The weather is also much better now and we want to ride as soon as possible.
Don't we ask for pics of girlfriend before making recommendations???
No pics, but she is 170cm x 55kg.
We tried out several different bikes in a couple of local shops. We rode them around the car park for a few laps, which may not have been the most insightful test, but it did confirm that she doesn't dislike anything particular. We tested a Bosch CX, Yamaha PW X3, Bafang M500 and Bafang M510.
She didn't like that the M500 doesn't assist you immediately when starting from a standstill, but apart from that it was as good as everything else. The Bosch had a slight edge over the rest.
As a side note, one of the shops was Agazzinibike. They have some outstanding bikes. They let me try one with a Bafang M510 and a custom firmware, with a whopping 1200W peak! The owner was very friendly and helpful. You must visit them if you are in the area.​
Today, we visited a shop that let us try two emtbs for a couple of hours on a local trail. One had a Yamaha PW X3, and the other a Bosch Performance CX. My girlfriend preferred the Bosch, but not by much. Although she liked that the assistance on the Yamaha is instant.
These are the best offerings I could find:
NEW
1. RAYMON TrailRay 140E 9.0 29'' 150mm 10v 720Wh Yamaha PW-X3 Nero/Blu Taglia M --> 2800€
- Telaio: Alluminio 6061, 140mm, Batteria Integrata, 12x148mm
- Motore: Yamaha PW-X3, 250W, 85Nm
- Display: Yamaha Display A, LCD-Display
- Batteria: Simplo EnergyTube, 720Wh, 36V, 20Ah
- Caricabatterie: Simplo, Caricatore Rapido, 4A
- Forcella: RockShox Domain R, DebonAir, 150mm, Conica
- Ammortizzatore: RockShox Deluxe Select, 230x57,5mm
- Cambio: Shimano Deore LG M5130, Shadow Plus, 10v
- Deragliatore: /
- Comando cambio: Shimano Deore M5130, Rapidfire Plus, 10v
- Pacco pignoni: Shimano LG400, 11-43D, 10v
- Catena: Shimano LG500
- Corona: R Raymon, Alluminio, Narrow Wide, 38D
- Pedivelle: R Raymon EC40, alluminio forgiato, ISIS
- Freno anteriore: TEKTRO HD-M745, freno a disco idraulico, 4 pistoni
- Freno posteriore: TEKTRO HD-M745, freno a disco idraulico, 4 pistoni
- Dischi: TEKTRO TR24 203mm, 6 fori / TEKTRO TR24 203mm, 6 fori
- Copertone anteriore: Continental Trail King, 60-622, 29x2.40
- Copertone posteriore: Continental Trail King, 60-622, 29x2.40
- Cerchi: Mach1-Trucky30, Occhielli, Tubeless
- Mozzo anteriore: R RAYMON DA210F, 6 fori, 15x110mm
- Mozzo posteriore: R RAYMON DA210R, 6 fori, 12x148mm
- Manubrio: R Raymon 35, 780mm, Sweep: 9°, Rise: 20mm
- Attacco manubrio: R Raymon 35, 40mm, 0°
- Sella: R Raymon MTB
- Reggisella: R Raymon 35mm, Telescopico, 100mm
- Peso massimo consentito: 130 kg
- Peso: /
2. WHISTLE B RUSH C5.2 750 Wh FULL CARBON --> 2600€
SPECIFICHE MECCANICHE​
TelaioFull Carbon 29, Toray T700, integrated battery, internal routing, Rear travel 150 mm, 12x148 mm E-Thru
ForcellaRock Shox 35 Silver R, 150 mm, Maxle Lite 15x110 mm, Coil, 1.5 Tapered, Lockout, E-Bike
AmmortizzatoreRock Shox RS Deluxe Select R, 230x65 mm
Serie sterzoAcros AZF-575, 1,5”, Internal routing
GuarnituraFSA, 34T MegaTooth
CambioShimano Deore RD-M6100 SGS, Shadow Plus
ComandiShimano Deore SL-M6100 Rapidfire-Plus, 12s, I-spec
FreniShimano BR-MT420, Four piston, Rotor SM-RT30 203 mm / 203 mm
Pacco pignoniShimano CS-M6100 12s 10/51
PedaliAlu MTB Full+
MozziF: Shimano Alivio MT400, 15x110, CL, 32h R:Shimano Alivio MT410B, 12x148, CL, MicroSpline, 32h
CerchiRADIALE X30, eDesign | Asymmetric, Tubeless Ready, 622x30c
Attacco manubrioSatori Ursa, 35 mm, Internal routing
Piega manubrioRise Alu Oversize, 780 mm
ReggisellaDropper Alpha 1, 31,6 mm, remote
SellaWhistle Performance
CopertureSchwalbe Nobby Nic, Performance, Addix, 29x2,60
Taglia40 44 48 52
ColoreBlack Matt/Rainbow Silver Glossy
SPECIFICHE ELETTRICHE​
Coppia massima85 Nm
Tipo sensoreTorque
Batteria750
Tipo caricabatteria4 A
Tempo di ricaricaUp to 6 hours
Velocità max assistita25 km/h
DisplayLED REMOTE
PotenzaEco: 60 %Tour: 140 %EMTB: Dynamic %Turbo: 340 %
Does anyone know this bike? Carbon frame, Bosch CX, 750Wh battery for 2600€ seems like a good deal to me.
USED
GIANT trance sx e+ --> 1850km --> 2000€
Scott eride 940 2024 --> 240km --> 2200€
I need to further investigate the reliability, reparability and serviceability of these two motors. And that will probably be the deciding factor.
    Join 43,188
