2025 ZF Bike Eco System - New Motor!
Some more info here:
You can choose subtitles from settings, and then go into subtitles again and choose automatic translation if you don't understand German.
But what I wonder is if the Raymon Tarok is a good hard hitting enduro-bike? Would like to know if it is worth waiting for or if I should go for some other bike that is on sale right now?
Has anyone found any reviews of the bike itself?
some impressive details for that motor. Sounds like a bit of fine tuning is required but thats just software. Depending what major brand adopts the motor it could well be a Bosch competitor.
I put out a similar Raymon Tarok review inquiry in January....nothing yet. Maybe German winter prohibits reviews and will be seen in late Spring?
But the Aussie YTers like Sam's Bikes should be available weather-wise, so if he gets a Tarok....well Sammy, did you get one yet?😁
For me, compactness really isn't super important, yet this seems to be their top priority. Unfortunately harmonic drives etc like this (and the TQ) are not super efficient, hence all the talk about heat dissipation.
Efficiency is super important (until we get lighter batteries). So hard to get excited about this.
💯 On batteries...the solid state version when finally brought to a commercial scale should offer much lighter weights for the same capacities.... probably will not be super cheap at the out set at least. 💸
Compact design of the ZF-90 gives it the opportunity to develop a compact MGU around it. They make auto gearboxes, so I'm hoping a nice compact 8-spd can be developed with their driveunit for overall full power, low profile design?
The HP-120 Nm is out there on an early Bulls bike (I think). But I wonder if overheating was ever an issue or just the 120 Nm wasn't really fashionable.
Ultimately, we'll have to see how the Tarok holds up to heat dissipation over time. We just need to actually finally see it on the trail.😁
Holy thread resurrection!
Is this the only bike running the ZF 'ecosystem'? I thought this may have been one to watch when it first appeared last year.
Interesting. Like Sram, they probably facing a whole host of problems including like you said Ton, as well as relability and compatibility. Getting long term contracts with top bike manufacturers for an unproven product must be hard. No new bikes from sram in like 2 years, if they cant do it...good luck VF.
True indeed.
If you were head of a bike brand planning out a new ebike, which system would you choose right now? IMO its a two horse race at the moment.
Avinox would be the obvious choice for full fats.
What’s the other one, Rob?
For mid-power (lighter emtbs) the choice is less obvious to me.
The problem with Mahle and any other brands is simple.
People buy BIKES , not MOTORS !
If you have issues with it, you don't turn to the motor brand you go to the shop or seller who sold the bike that has to address go to the bike brand or send you on a complicated route with the motor company. This means downtime which really upsets the owner and give him seconds thoughts.
That's why big brands really don't want to stain their name with somethings that is either :
1. reliable
2. easy to service.
So the top in the gain remains only Bosch and Avinox / DJI matters because :
1. Bosch have the numbers and cash flow and super extensive wlarge service network
2. DJI has the cost down as there is no loop from the ground factory that makes them, till the dealer that can receive a motor in short timeas it's from the super low production cost
hopefully with some refinement this motor can make a comeback. As mentioned, just needs a slimmer battery to really make for an awesome design.
Review I read suggested it faded out about under load and was noisey.
Let’s hope this isn’t the end.
Only trail ride review I've ever seen was recently last Summer '25. Very positive. Looks like the hulking battery is a mismatch to the tiny motor and the integrated display needs upgrading. Also on the positive, new firmware upgrade, they just bumped up the torque from 90 to 105Nm.
Looks like the ZF motor is no more :-( @Greg Watts summarise this article Is ZF calling it quits on the e-bike market?
Well, this is a eulogy I was rather hoping I wouldn't have to write. The ZF Bike Eco System story, as told through this thread, is a textbook case of promising tech that never quite found a dance partner. It arrived in mid-2024 with genuinely impressive specs on paper: a motor roughly the size of a TQ but with nearly double the power, oil-filled and guaranteed for 30,000km, with a clutch mechanism that decoupled the drivetrain from rock strikes. On paper, it was the sort of thing that should have had bike brands queuing up.
But the cracks appeared almost immediately. @tooFATtoRIDE was disappointed from the start, arguing that ZF's automotive gearbox expertise should have led to an integrated MGU solution rather than just another mid-drive motor. @G-Sport echoed the sentiment, noting that the real revolution would be an SL-weight MGU, not just a lighter conventional motor. The batteries were a sore point too, with @Rando_12345 pointing out that the energy density matched two-year-old packs, which rather undermined the motor's weight savings.
The warranty terms sparked their own debate. Despite the headline 30,000km figure, @AF1 spotted that the fine print excluded water submersion, and @tooFATtoRIDE delivered a fairly scorching assessment of the warranty's vagueness and the broader right-to-repair problem across the industry. @billium's plea for published service manuals and available spare parts felt increasingly prophetic.
Then came the long silence. By late 2024, @TCFlowClyde was asking where all the reviews were, noting that only Raymon's Tarok seemed to exist as a real product. DJI Avinox had arrived and hoovered up all the oxygen in the room. The thread went quiet for months. When it resurfaced in late 2025, @Bogdan_CH nailed the fundamental problem: if the big bike brands don't adopt you, you're on a quick road to closure. People buy bikes, not motors, and without a proper service network or major brand commitment, even excellent hardware dies on the vine.
@B Rabbit held out hope that with refinement and a slimmer battery the motor could make a comeback, and @TCFlowClyde noted a positive trail review and a firmware bump to 105Nm. But one bike, one brand, and one firmware update does not an ecosystem make.
The moral of the story is one we've seen before with SRAM's motor efforts: you can build brilliant hardware, but if you can't get it into enough frames with enough dealer support, the market will simply route around you. ZF had the engineering pedigree, a genuinely clever motor design, and the automotive credibility to back it up. What they apparently didn't have was enough bike brands willing to bet their product lines on an unproven platform when Bosch's service network and DJI's cost advantage were right there. A shame, genuinely. That clutch mechanism deserved a longer run.
  • Crap Post
Reactions: rzr
I think a few brands probably got burned on other motors. If you design a frame, especially a carbon frame, around a particular motor and invest hundreds of thousands of dollars in tooling for that motor in several frame sizes, and then that motor has reliability issues or fails to deliver on specs like a range extender, then you face a big financial and reputational loss due to factors entirely outside your control.
IF, small motor manufacturers could settle on a fairly universal mounting standard, that was say adaptable to TQ, Fazua, Maxon then it would be way easier for frame builders to commit to that standard knowing they had other options to fall back on.
ZF like Bosch is heavily tied to the automotive industry which is really struggling especially the German manufacturers. Bosch announced they won’t have a booth at the big Euro bike show this year which is a shocker.
Seems also shimano will not attend eurobike....
I think this is primarily because many industry players are unhappy with the organisation of Eurobike and are withdrawing their attendance as a form of rebellion against the organisers.
    Join 43,137
