Look the same to me, but what do I know?Thanks Irie. I think I missed your post. Are the new ones made of a different material do you think?
PS - I didn't fit the 'O' ring.
Hold it with your left hand.Any good tip, how to hold the left side crank still when torquing this nut?
Imagine that been the case on the old plastic bigger ones !! I gotta be honest i think there no more effective than spacers or washers minus treads.if your chainring and crankarm can tighten up against the chainring id bet it would keep it held but id put as much torgue as the bolts that hold it on onto them,try a Yamaha locknut now thats up in the 50'snm atleast ive seen the opposite side snap the outter piece that a chainring would fit on and it was placed in a strong vice and the pedal put back on the side that gets clamped to the vice but on them there square taper so wouldnt he have been better clamping the actual crank? maybe it would spin sorry for going off topic but there was reason as a extremely tight lockring can cause alot of headache and it was just to change a 20euro casing bearing a job that ive to do but ive a better plan i hopeAfter following Bosch instructions (grease don't loctite) the chain ring lockring nut to 25 to 30 NM and having it fall off 3 times I was pretty annoyed and about to start looking into drilling it out and using safety wire. I even went to the local Trek Dealer and had them torque it down in case my torque wrench was to blame. Most local Trek dealers just state the Torque is 25 to 30 NM (as printed on the part) - when you call Bosch if you are lucky you will get someone who will read an outdated manual and confirm the old torque spec. However, what Bosch consumer support and most Trek folks don't know is a Technical Service Bulletin was issued by Bosch that stated the spec on the lockring is actually 40 NM to 45 NM. When my wife and I dropped both chain rings while riding on vacation, thankfully we found a local mechanic who actually cared about solving the problem and informed me of the change in torque spec - he torqued the lockrings on both our Trek Rails to 45 NM and so far after 300 miles they have not moved.
V
Or go oldschool if motor still on the bike lean the pedal on a curbHold it with your left hand.![]()
No please!
same as removing a stubborn pedal...........get the non drive side pedal up against a worktop bench leg or similar.
fyi Bosch increased over the years the torque for tightening the lockring - think this was mentioned somewhere in this forum before.
Yes, probably best way is to mount wheels, take the bike down from stand for tightening.No please!
This is the simple way to do it:
Good to have a quality nut and fyi Bosch increased over the years the torque for tightening the lockring - think this was mentioned somewhere in this forum before.
Some men on a big island between atlantic and the north sea are able to do it with simples stones along the road!
Pic of the Day
After a f#ckin cold and misty week they said… ….it will be sunny. 😀 They said.🙄 …it will be 5 celsius. 😀 They said. 🙄 Gave up hoping after noon, took a tea along and went biking. About 2 hrs in the mist and in the cold with some nice winter impressionswww.emtbforums.com
I did put blue. But not sure if it do much. Thread is so low and with splines. And my opinion the chainring interface needs grease so threads are not completely decreased. Buts what's the thing with that rubber o-ring? What it should do there? On second bike, new one, the o ring was already in several pieces.do you use thread lock by any chance ??
Many new bikes do not have the O ring fitted, looks like a failed attempt to prevent the lock nut from loosening ...I did put blue. But not sure if it do much. Thread is so low and with splines. And my opinion the chainring interface needs grease so threads are not completely decreased. Buts what's the thing with that rubber o-ring? What it should do there? On second bike, new one, the o ring was already in several pieces.
irie said:When I changed the chain ring, as recommended by Bosch, I used a new nut but didn't bother with the O-ring because it was bound to be squashed and/or ripped when the nut goes on. Used a bit of blue Loctite. And IIRC the new nut had 35Nm marked on it instead of the 25-30Nm marked on the old nut.
Bosch sure have increased over the years anyone remember the big 60mm plastic lockrings mainly on haibike im sure it was just support to hold the chainring in place,gotta admit those classic motors that were put on proper mountain bikes had serious strength there let down was the big plastic cogs and so many of them,they had caps in them the size of a treble a battery 2 of them,my one was like a wild horse lol still runs now and gets usedNo please!
Pic of the Day
It was a figure of speaking, but when the nut comes loose the chainring comes loose. Guess what comes after that?That nut has nothing to do to keeping pedals on![]()
So you evidently know better than Bosch engineers.If the nut is in good condition, i would use it again. It is ecological, perfectly fine, and much more convenient than ordering new from somewhere. I would say that already mentioned three times before replacing is reasonable.
He does not know better, he is in line with it.It was a figure of speaking, but when the nut comes loose the chainring comes loose. Guess what comes after that?
Smart Aleck Mode On:
The pedal (crank arm) will not come loose on a Bosch until loosenig the crank arm screw on the axle (e.g. to pull the crank arm off). Chain ring is separate from crank arm.
Smart Aleck Mode Off
I prefer to follow Bosch instructions for devices it designs, but you are of course perfectly entitled to do whatever you wish with your property. But saying that, "one swallow does not summer make" (English idiom often attributed to Aristotle).I re-used the lock ring on mine with proper tools and acc. to Bosch manual and had no probs so far.![]()
