Kenevo SL Official 2022 Kenevo SL (KSL) Megathread!
After SPesh released the KSL 2, i really believed they would use the great frame / geo of the KSL 2 to deliver a fullpower K.
After riding one, i feel even more bad and sad, to say the least :eek:
My mrs is though. I’m wondering if a 26” wheel will fit in the back.
24’’ clearance
Thanks. Doesn’t look like a 26” wheel will fit. 😢
I'll have to dig the Zaskar out of the garage and get some measurements for comparison.
I have been riding the Kenevo SL expert 2021 for almost 2 years now with the 1.2 engine (without changing the TCU or battery), and the engine assists up to 33km/h.
I was told that I could limit it to 25km/h, 33km/h or unlimited, but the latter didn't make much sense knowing that it is a low-power engine. So I left it at 33km/h which is ideal.
I'm still amazed why Specialized doesn't sell the 1.2 engine separately at this point...
Yeah mine has a £200 delimiter on from the previous owner. Does seem a bit pointless on an sl.
I bet if i took it off and went back to 15mph though i would be moaning like hell 😁.
My KSL 1.1 has stopped turning on or charging.
I've tried plugging in the charger and turning on a few times, also cleaned the charger connectors with contact cleaner.
Think the internal connectors might need a clean.
Anyone have any instructions or youtube videos showing how to remove the battery - I think it's like the Levo etc but I need to remove the charger connector first, to get the battery out.
TVM, John
TVM, John
Think Rob showed how to do it in his KSL video.
TVM, John
Mine does this sometimes and if I disconnect and reconnect the TCU it usually sorts it out. Just remove the little screw holding it in the frame, remove it, and completely disconnect and reconnect the wires to it.
Thanks Dax,
The only video from Rob, I could find is the first one on page 1, unfortunately this doesn't show how to remove the battery.
Am I missing something ?
TVM, I tried that and also charging the TCU through the USB port.
Interestingly, if I connect the USB I can turn off and on but when on I get the message: "No Battery Check App & Connector".
I wonder if the battery needs replacing and if this is even possible?
Is the bike still under warranty?
You can get brand new internal batteries for the KSL off Certini for ~£400, but I’d want to make sure that’s actually the problem before spending money on one.
Are you sure the older model TCU battery can be recharged? I think there was some instructions on how to replace it.
TVM Mine definitely has the rechargable battery. Here's from the manual:
If the system does not power on after a long period on non-use, remove the​
MasterMind TCU from the top tube and charge the MasterMind TCU via a​
USB-C cable.​
I tried charging for 3 hours but bike still won't turn on 😭
TVM
Not sure it is still under warranty but it's due for a service so I figure I'll get my LBS (A specialized dealer) to sort it when I take it in for its service 👍
Quick review/update on my electrical problems, in case this helps anyone else in the future.
1 - The TCM wouldn't turn on
2 - Connecting power to the USB port and the TCM reported "No Battery Check App & Connector"
3 - Connecting a range extender and everything worked but was only reporting 50% power
4 - Removing the motor and checking the battery connection and everything looks OK
it seems like the main battery or main battery harness has failed.
Fortunately the bike is going in for a full service soon so my LBS (A specialized dealer) can take a look
Hi,
Can you please let me know if you simply plugged it in or did you have to take to a dealer to have the TCU reprogrammed ?
Many thanks,
Andrew
Already posted on the "what did you do to your ebike" thread but I'm hoping to catch someone on here who's seen this before.
Brand new 1.1 KSL frameset (purchased direct from Spesh in November 24), never ridden or even been sat on as I've not got round to building it up yet -- it's a spare for my existing one.
There's 3mm of play on the motor spindle, I think it's different to the crank play issue as it looks more like there's something missing in the middle of the motor?
Call the ebike motor centre, they told me you have to do the non drive side crank up before the drive side, or it is the opposite way round, if you don't it can pull the spindle from an internal bearing ( Or something similar ) but that video defintely looks like what the described to me, I know I'm sounding a bit vague but think that will be the case. Not sure what the fix is but probably a warranty motor in your case eBike Motor Repairs & Servicing - Homepage
Still happy with the KSL!
I'm hesitating to sell my Transition Spur, I'm spoiled by the ease of the Kenevo... I feel like the only non electric bike I really enjoy pedaling is my road bike now.View attachment 154795
I find the spur is a great compliment to the ksl, it’s different enough to justify owning. I don’t ride much, but everytime I do, I find it really rewarding
Nice, I don’t want to derail the thread too much but what’s your setup?
‘23 Spur, stock GX build apart from a CCDBil and carbon bars. I might change the brakes, but otherwise it’s perfect, such fun to ride, responsive and agile.
    Join 43,287
