Locking chain wheel nut
aerodiamond
Bedfordshire uk
Has anyone found a way of locking the castelated chainring nut on bosch gen 4 drive units. Locktite last about six months. I thought of drilling the nut and wire locking but there's not much metal to drill into. Any ideas
Nigel
I torque the nut to 40 ft/lbs. The same torque setting as the cassette lock nut.
Never had one come loose. Apply a touch of “ Copper Slip” anti-seize to the male thread to prevent the thread from picking up.
Correct me if I'm wrong, but 40 ft/lb is about 54 Nm! 😲 Isn't the cassette lock nut about 40Nm?
Nigel
If you mean chainring lock nut, it's 25-30Nm and it's printed to the nut. And it's good to check the o-ring at the same time.
See the below post - it is now 35 Nm
Edit: I used blue medium strength thread locker (Loctite 243) and put on tell tales so can immediately see if loosening. 6 months later still not moved. (y)
Bosch Gen 4 Chainring Nut printed Torque of 25 to 30 NM is likely wrong
Also put tell tales on cranks for exactly the same reason.
I always thought that the torque could be increased slightly for this nut. I’ve removed it several times on different bikes especially when replacing a chainring or bearing seal kit.
My first attempt was a little difficult because my bike was suspended and moved around. Besides the left-hand thread, the castle nut removal tool would slip. There is a tool available which insures proper and secure attachment, but it’s expensive.
A rubber “O” ring was not installed with the original nut. But a brass “O” ring was along with a thin plastic “O” ring. When I installed an ethirteen chainring the chain alignment was incorrect. I had to remove the brass “o” ring and only use the thin plastic one. The ethirteen has an integrated spacer, or “o” ring.
I added a small amount of blue lock-tight to the castle nut threads and torque to the correct setting. That worked fine for the life of the chainring.
After removing the castle nut several times, this aluminum nut became slightly damaged. It’s very easy to accidentally cross-thread. The threads on the castle nut may have been stretched after repeated torquing. (After all, it’s only aluminum).
I’ve ordered two castle nuts. One as a spare and one as a replacement.
When I removed this chainring I discovered that the castle nut was loose. IMO the old castle nut is toast. No damage or noise occurred that would peak my attention. But this will become part of my regular preventative maintenance. I’ll watch this more often.
Nigel
My lock ring has come loose twice - first time after ~4 months, then again almost exactly a year later.
It's a good example of why I hate bicycle mechanics. Something is loose that must be tightened, should be dead simple. Except you need a special socket for the lock ring (specific not just the manufacturer but also the model), and to get to it you have to remove the crank, which requires of course the specific crank-puller. Pah.
I haven't considered locktite yet, but I've learned to keep an eye on it and check every couple of months. Last time I tightened as much as I could.
Nigel
40 nm and since then no need for loctite or safety wire driling out of parts. I have two bikes that this has worked for after 1 year of having charin ring droppers - local bike shop that rents Trek Rails also uses this spec as they got tired of having to rescue people with dropped chainrings. For more back and forth you can read the above link, mostly its folks that will not change the torque on a nut that is printed 25 to 30 nm vs. me trying to get them to realize Bosch just screwed up when the printed the spec, but hey everyone is enttitled to their own approach on this issue.
    668K
