2025 Wild ST vs 2025 Rise SL
jgf
Canada
I had the new Rise SL with the 625 kw battery shortlisted on my list of candidates (H20 or M20 version) but the new Wild ST (short travel) has made things unexpectedly interesting? Wondering on peoples thoughts here. I am absolutely more of a trail rider but I have to say that the new gen Bosch CX motor of the Wild is waaaaay more appealing to me than the EP600 in the the two Rise models i am looking at. Presumably the Wild is going to be some amount heavier but Orbea is super cagey on their weights so maybe not all that much?
Basically a 2025 Wild ST and the 2025 Rise models seem to co-exist in the same space. Thoughts on the two vs each other?
I haven't ridden those ST/SL models but i was just test-riding and deciding between a Wild and Rise and was riding those motors back to back.. The Bosch is more torquey/stronger but the ep6 was impressively strong for how (very) tiny it looks.
The Wild is going to be considerably more stable/planted/bump-absorbing and the Rise is going to be more light/agile/playful. They were both awesome.
I don't know that they really would occupy the same space, even if you took some travel off the wild and added some to the rise. The Wild is not lightweight, it feels like a beast (in a good way, though).
If you want to go fast over rocks/roots and/or be super stable all the time, get the Wild.
If you are going to mostly be riding smoother trails and want a lightweight, playful, nimble bike get the Rise.
That is probably an oversimplification.. but it's how I saw it. They are both fun. The Wild is probably like 10 pounds heavier than the Rise, the Rise is truly light. I live in the mountains and picked the Wild, it gets delivered this week!
Hi All,
Do you know if the 2024 Wild ST H and "normal" Wild H are using the same/identical alloy frames, just with different shocks and shock stroke/travel?
Cheers
Not sure where to post this but assume this is a 2025 Wild. They’re claiming 43 lbs. I call bullshit. Anyone think this is possible?
Orbea is so annoying with not posting weights (even 'as configured' weights would be helpful). I think there is a zero percent chance that a 2025 Wild is 43 lbs.
(For the metric among us, 43lbs = 19.5kg)
They’ve probably done what they did with the Rise when it first came out and weighed it with the lightest possible tyres, no sealant, smallest size frame etc. It’s disingenuous but seems pretty standard.
That can't be the standard method of routing cables through the headset surely? I don't care that much about the visuals of cable routing, but that looks absolutely horrendous, and must be even worse when on the bike.
someone on that spokex_ instagram asked how they got it down that light and their answer was 'nothing its a lightweight model'.... very sus...
(honestly if orbea has even a 20-21kg equipped wild I'd be pretty interested but thats into Rise SL/LT territory so very sus...)
I've got the 2024 Wild and no, that's not how I've routed the cables or how I've seen any other Wild owner route them either.
They look to use the same headset too. Maybe the mechanic was having a bad day 😂
Hello everyone. I'm Tomislav from Zagreb-Croatia.
I received my Orbea Wild st h30 2025 on Friday. I installed some of my own parts (zeb170, float x shock, hayes dominion, mavic e deemax mullet wheels and mullet link. The bike is like a full orbea wild.
Where are you located in Canada?
What size shock did you install? The ST has a 205x57.5, if you install a 205x65 the bike will have a 170mm rear travel like the standard one, at least that's what I believe from looking at the one we have at our shop.
There's no chance you could get to 43lbs. An M10 with the 600wh battery will weight in at 49-50lbs depending on the comments. I've weighed a 2025 M10 with the 750wh battery with pedals and it's exactly 53lbs on our scale.
hello. I put a 205x65 shock and a 170mm fork. so is like full wild . weight with 600wh pedals and everything as in the picture is about 53 lbs. H30 st model
That would make sense seeing that the new 600wh battery is 3lbs lighter than the older 750wh battery.
Hello fellow non-european! :)
Edmonton Alberta. Wife and I like to get out to the mountains at least two or three times during the season but most of our riding is in the city trails/river valley park system. Even in the mountains she's not a fan of anything too scary so I'm not really looking for a bomber...
Totally possible with careful parts choices, but will be expensive! I do agree to call BS on that build though, and the 38s and rear X2 are WAY heavier than competitive alternatives like a Mezzer Pro and a much lighter piggyback shock.
I'm intending to buy a 2025 Wild M10, and rotate either a 57.5 light weight shock and a 65 bruiser, changing the fork travel on my Mezzer Pro between 150-160mm. My calls (based on real world weights) estimate 44lb quite easily achievable, and could go sub-42, but with prioritising weight saving and more flimsy weak components which will hold the natural bike back.
Has anybody else gone for the ST Wild? Im wondering about getting one, the alloy M30 with the 600wh battery.
It seems like it might be a good compromise between weight, nimbleness, price and decent battery and power.
I appreciate it might need some upgrades from the box also.
I bought st h30. but i put fox float x shock, fox 38 170mm fork, hayes dominiin brakes.... mostly upgrade to full wild. 600wh battery and powermore 250wh. I am very satisfied. good range with battery and extender, and only battery for short driving during the week.
Can I ask why you didn’t go for the full wild?
Oddly I picked one of these up in the shop the other day and was surprised how much , or less it weighed than the aluminium 2024 one my Mrs owns I was looking for the rise sl btw coming from a fuel exe , did make me think of buying the carbon wild
Was that J E James?
Am also interested in the ST H20 version. Would this feel a bit more nimble than the 170mm travel version?
Looking for a trail inspired bike but want to stay with Bosch.
I believe the 600wh battery is much lighter than the 750wh. It’s perhaps telling that the wild M-team and M-Ltd are shipped as standard with the 600 battery, presumably to keep a low headline weight. The Rise LT seems to overlap, but I’d be erring on the Bosch motor of the wild.
I looked at a regular wild m20 in carbon and, surprisingly, the carbon frame did not have the blanking plate for the upcoming Bosch integrated display.
Do you know what the weight of the stock ST was before you started modifying it?
Watch this.
Hi, did someone try 205x60 shock without mullet conversion (29/29) on ST 2025? Just bought the ST20. Thx in advance
