Hi Arild,Hi Cobee!
I am stunned about your work - and would love to buy a set of adapters.
Unfortunately I got a link to your work by a friend, so I am new to this forum and can not send PM's yet.
I really hope you still have available adapters in stock for me.
Best regards,
Arild, Oslo - Norway
Hi Janne,Impressive work, @Cobee !
Isn't it correct, that a gen4 motor could be configured for derailleur or internal gear hub shifting? From what I've read those differ in how the motor detects that shifting is occurring and in how the motor lowers power that moment.
If that is correct, then is it an issue if you mount an IGH configured motor to a derailleur bike or vice versa? Can you know which one the motor is from the diagnostic report? Can this setting be changed by workshop? So many questions, bear with me. have an IGH bike with a 2016 Performance Line gen2 motor. I would like to put a gen4 motor to it.
Regards,
Janne
Hi, I will - the adapter was bolt on - but I have some issues to modify the original egg-formed cover used on 2017-2019 (by Cube, Trek, Riese&Müller and others) bikes, so I struggle with some esthetic details . After my vacation I will try to make a 3d-printed cover to make the conversion better looking. But as said - your adapters was bolt on - very easy to mount, and I can not see any better way to modify it to make it easier to adopt the egg-cover, so I will work more with the cover to make it fit better on my Riese&Muller Delite (2017).Hi Arild,
I hope your conversion on my adapters will well.
Show us your progress. I’am curious. Good luck.
Hi Janne,
Unfortunately I haven’t idea how work autoshifting. My conversion done with non-smart gen4 motor. Is the easiest way - battery and controller is compatible.
If you need adapter with bolts please let me know.
Paweł.
Hi,Hi, I will - the adapter was bolt on - but I have some issues to modify the original egg-formed cover used on 2017-2019 (by Cube, Trek, Riese&Müller and others) bikes, so I struggle with some esthetic details . After my vacation I will try to make a 3d-printed cover to make the conversion better looking. But as said - your adapters was bolt on - very easy to mount, and I can not see any better way to modify it to make it easier to adopt the egg-cover, so I will work more with the cover to make it fit better on my Riese&Muller Delite (2017).
Hi. Is the same. But gen4 chainring is bigger of course.Does chainline change? I mean is the distance of the front sprocket different with gen 4 vs. gen2?
Excellent! Thank you!Hi. Is the same. But gen4 chainring is bigger of course.
Hi! It is a city bike, Lapierre Overvolt Eden Park with a 2016 Performance Line (non-CX) motor and a Enviolo/Nuvinci N380 hub. It has an eggshell shaped motor cover so perhaps Trek Powerfly covers do not fit.What bike you have ?
If someone have a Trek Powerfly 9.7 or 9.9 I have a complete fitting covers for these bikes. For Other bikes frames, covers need to be fitting individually. Sometimes original are correct sometimes not.
Have a nice day![]()
Excellent jobThis is my bike with original motor, cranks removed.
And Gen 4 installed.
Cables are not routed properly, yet. Right cover fits mostly but left needs to be modified. Or a 3D model designed. For now I think I'll just cut the left cover so that it fits and add some Sikaflex/sealant/adhesive if needed.
I will be able to test ride the bike tomorrow if I can find sprockets.
Anyway. Impressive adapter kit you have provided, @Cobee !
Thanks for providing hex bolts in the kit! They are much easier to work with than the odd Bosch Torx Plus screws. I did not have the correct torx bit but was still luckily able to remove the Bosch screws.Bit for unscrew original bolts for adapters.
Bit do śrub Torx Plus®, 1/4 cala E 6,3 z otworem, Torx Plus® profil IPR: 25IPR | Hoffmann Group Perschmann
Kup Bit do śrub Torx Plus®, 1/4 cala E 6,3 z otworem, Torx Plus® profil IPR: 25IPR w eShop Hoffmann Group Perschmann: ✓ Osobiste doradztwo ✓ Polecane produktywww.hoffmann-group.com
Please be carefully with threads in alu zinc material of housing motor. Not screw more than 9-10Nm. Is easy to broke this threads.
3D prints (PETG) and hot glue (too much). Not pretty but works.Later I will 3D print black disc with a hole for crank and glue it to the case from the inside. Also same for the logo hole. Perhaps a spider with some offset would have worked instead.
In case someone wants to try to design a cover for a frame with Bosch classic rounding, here is a scanned 3D model of a mounted motor without covers: Bosch Gen 4 Motor On Gen 2 Frame - Download Free 3D model by Alavin . I am learning Fusion360 but it might take a long time to get anything done.
