Ohlins TTX o EXT Coil + Cascade LinkEn senderos técnicos con muchas raíces y rocas, ¿qué actualización de Turbo Levo SL gen2 tiene un mejor efecto de conducción, a) bobina EXT e-Storia o b) ruedas de carbono?
*Por cierto, ya pedí el GX Eagle AXS.![]()
I am running shock in low, cs in long, and fork in -1 with mullet and it rails! The long cs makes the front/rear center ratio better. I run 160mm cranks and run 24% sag in rear and never have rock strikes riding very technical high speed rocky descents. This thing also jumps very well.View attachment 143676
Got the bike - love the color and looks!! Rides very well too
Question to current owners: I've seen on another thread folks using the 29er setting with the 27.5 wheel in the rear, to lengthen chainstay and wheelbase (like Matt suggests in this article's "geo and sizing" section). Did other riders here try this setting and if so, what's your frame size and what are your impressions? Thanks.
Are we finding the dropper cable moves quite easily in the frames? I’d love to get a longer dropper as I have a fair amount spare (240mm from frame to saddle rails) but Specialized think there is only 200mm insertion depth. I don’t fancy having to strip lots of stuff out of my new bike just to try to replace it.I have size S3 and with the stock 150mm dropper I was not able to slam it all the way down. I have switched to a smaller diameter 31.6 PNW 170mm dropper and can get the same insertion depth as the stock dropper but with more travel.
yeah, that's an obvious choiceI couldn’t wait so I inserted an EXT![]()
I don’t have experience with Genie, but the Storia V4 is quite tunable, yes LSC-HSC-LSR-HBCyeah, that's an obvious choice
will it be as tunable as GENIE?
VASTLY superior
but not the progression rate of the springLSC-HSC-LSR-HBC
The ext Storia has a hydraulic bottom out, in fact the best in the business. They developed it thirty years ago in automotive. It is the superior shock on the market. Only thing with potential to be better is Vorsprungs new shock. If someone still thought they needed even more progression they could buy a progressive spring instead of a linear one. I’ve never seen a person who needed a progressive spring on a Storia.but not the progression rate of the spring
I had an ext E-Storia on a turbo levo- simply sublime. Tried the tigon which was also a great shock but not as good.I can corroborate. I have the Storia on my SL and the Vorsprung Telum on my analogue. They’re the best shocks I’ve ridden, and unfortunately I’ve tried a lot. They go about their duties in different ways, but both are phenomenal. They cost more, but not having to buy and guess spring rates makes up for a lot.
Where there is a weird fluttery wallowing there is perfect support and traction, where you are blowing through travel in inconsistent ways you are finding support and a mid platform to kick off of, where there is an unexpected clang at bottom out there is a smooth and controlled ramp towards the end, and most importantly, you are getting all three without compromise unlike the usual 3 choose 2.In terms of feeling of the bike - what’s the difference between the stock shock and a fancy one?
Hi there. Would like to fit coil shock to Levo SL gen2 but have no idea which spring rate to start with. I am 80 kg kitted. Any suggestions?
Thanks for help!
www.tftuned.com
You can try this:Thanks, I know that calculator. I am more interested in personal experience of Levo SL coil riders with weight about 80kg.
80 Kg + Ohlins = Súper Alloy Racing 475Hola. Me gustaría instalar un amortiguador de muelles en el Levo SL gen2, pero no tengo idea de qué tasa de resorte elegir. Peso 80 kg con el kit. ¿Alguna sugerencia?
¡Gracias por la ayuda!
Anyone looking for short cranks for SL1.2 motor, these seem to match the part number and don't involve going to a dealer to order
Specialized S211600035 Turbo SL Crankset M20 Mountain 155mm SRAM
Specialized S211600035 Service Partwww.certini.co.uk
Warranty. Barely 2 months old and nothing to suggest they have a weight limit.This aged well, cranks are now bent. Where do I go from here?![]()
