Yes
Yes
I think it was the speed and fun or something like that. Came from Italy I believe. Works really well. All it does is trick the speed sensor into reporting lower speed. It's a marginal thing for me. I can still pedal with her, for a short burst, LoL. But if you are on a long flat you want to be over quickly, you can zoom over 20mph pretty easily. On climbs, doesn't help at all unless it's a super mellow climb. Like 1-2 percent grade.Curious which one you used and if it works well. For general riding this doesn't seem to be needed but for commuting to the trail it seems like a good idea, the bike is much harder to pedal at the same speed as my trail bike on the road and feels a bit slow vs cars and other riders (which, funny enough, feels a bit more dangerous actually)
www.twowheelsempire.com
like for cable damping? I use Jagwire.
So my motor has begun to rattle. I had been chasing this rattle for a little while. Started maybe 3 months ago. I've determined that it's the motor engagement that is rattling. Like, ride DH with the pedals flat and the shaking of the bike makes the motor engagement click back and forth quickly. It's quite annoying and I think I'm going to approach Fazua about providing a replacement under warranty.
Motor performance is fine, predictable, still strong, still quite under power. Bu when not under power, it's noisy. I can ride though a root ball coasting, noisy. Pedal through same root ball, nothing but tire noise.
True, I'm not even sure how long the warranty is for the motor. I just don't want to miss it.I wonder about pulling the trigger on warranty- If it were me and it isnt impacting power, would it be better to wait till further motor revisions come out
Do we know if motor warranty extends for 24 or XX months after replacement?
I picked up my bike mid August 2023.Warrenty is 2 years, it doesn‘t matter if you had a replacement motor inbetween.
My 2nd motor has no issues so far, but just 1100km in.
How much you guys have on the clock?
Mine is „Motor Type: Motor F4“ produced in Jan 2024 after replacement end of April.I only have 620kms, and 6 months in, my motor knock on wood has performed the same since day 1
- Really loud engine whine when in pink
- Slight engine whine in blue when mashing
- no engine whine in green ever
I think I have the V2 or v3 engine, does anyone know how high up they are now? I wish Fazua would post their revisions about each change
yes, been there. Remedied all of it prior to this incident. Even still, the first thing we did was tap on the battery to see if that was the issue. It wasn't.I had the same problem with my relay when I first got it. It was a combination of the battery clip not holding it in well enough and a pair of zip ties not letting the battery seat fully into the bracket.
yeah, bud. Done it all. I bend the battery clip from the back so that it barely touches the battery when inserting it to make sure it has the tightest connection possible. I have re-organized all the cables and replaced all the zip ties to ensure optimum placement and to ensure they are all tight. I've got all the excess wires tidy, zip tied up, but not too tight. But those are things I did when I got the bike as I have owned another Relay for about a year now. So I knew most all of the Relay's idiosyncrasies and addressed them.So, one of the ways I QA/QC'd this was that I put some adhesive backed neoprene on the battery door (adhesive side to the battery door) and then held the battery door tight to the frame with a velcro strap put on very tight. This basically allowed the battery door to push the battery into place instead of just the latch/metal clip.
Once I did this, I could bunny hop the bike and it would stay on. Remove strap, remove battery door, bunny hop the bike and it would shut off. This gave me the proof I needed to be certain that it was just getting the clip bent just the right way to keep it in.
I know you've checked all of this in terms of it being tight... but it's tough to isolate something like this in the shop as you're not re-creating the exact conditions or vibrations. Have you thought of giving something like this a shot to narrow down what you're chasing?
Not really trying to chase it down, just outlining the incident for community sake and if I it happens again, I'll have an accurate description of the events.![]()
Interesting turn of events this weekend regarding this issue.had a weird experience with the GF's bike yesterday. About 6 miles in, bike turns off on a big bump. Does it a few more times and then seems like any movement and the bike turns off. This progressed in a matter of 3 min. I inspect the battery connection and the spring clip to make sure it's all snug. Nothing is blocking the battery from seating properly. Bike turns on, but lift the rear end off the ground 1" and drop it, bike turns off. Wiggle the bike, turns off, tap the saddle, turns off, compresss the rear suspension, turns off. (turns off as in, LEDs go off, then single blue light at the top, then no lights. Activate the ring controller and it turns on like normal.) Through all of this testing, I've checked the battery power wire to the motor, the speed sensor wire connections and ring controller wire connections. All good. I loosened the wires below the battery and wiggled them around while the bike was on, did not turn off with pulling, pushing or wiggling the wires. Even loosed the ring controller bolt on the bars in case it was too tight.
Bottom line, the bike wouldn't stay on. Test it at the car, same results. Test it at home, same results. Throw it on the stand, pull the shock and begin to pull the motor out. Loosen all the bolts, removed the non drive side bolts. Decide to put the battery in and see what happens. Turn the bike on and start knocking on the frame, saddle, morning the rear triangle up and down, pulling and pushing on the dropper cable, wiggling the wires, tapping the motor with a rubber mallet, spin the pedals to engage the motor, no change. Bike performs as it's supposed to. I decide I don't want to pull the motor so I locktite up the bolts I removed and put them in. Re-torque everything, pull it off the stand and turn the bike on. Repeat all the things on the trail that caused it to turn off, bike stays on like it should.
So I hook it up to the tool box to see if any there is any information recorded, fault codes, etc... Connects and is recognized immediately, runs an update and everything looks fine.![]()
That's my guess, assuming it happens when out of the saddle.hey, thanks everybody who posted here! a lot of useful info.
currently fighting rattling/squeaking around BB. happens whenever I pedal really hard uphill. think it happens more on the left (non-driving) side, though happens on the right too.
what would be your guess, is it the motor bolts?
That sounds weird. Wobbly inside the motor threads or wobbly inside the frame holes?Had my motor removed and just randomly tried to put the bolts back without installing the motor. 3 of the 6 bolts are wobbly as hell. Guess the threads got destroyed while I was riding with those bolts being loose.
Should I put some money aside for the frame replacement?![]()
Wobbly inside the frame holes. Check the clip: The first 2 are snug, but then the last one doesn't stay put at all.That sounds weird. Wobbly inside the motor threads or wobbly inside the frame holes?
In most cases the creaking comes from the sleeves the threaded blocks slide into on the drive side of the bike. Not the bolts themselves or the bolt / frame or motor / frame contact points.
Speaking of the sleeves -- do you need to remove them from the motor to add the paste? How do I do that? Do I just pull on those springs?That sounds weird. Wobbly inside the motor threads or wobbly inside the frame holes?
You've got nothing to worry about. I'm about 98.3% sure the bolt holes in the frame aren't threaded. In my estimation, the only reason some thread in tight and some feel more loose is due to an excess of loctite in the bolt holes.Wobbly inside the frame holes. Check the clip: The first 2 are snug, but then the last one doesn't stay put at all.
Yes, those sleeves is what's causing the creak. It can be tricky. I thread the bolt into the sleeve, use a small paint can or something solid as a leverage surface. Then I use a small pry bar to pull them out by the bolt head. I actually use an interior door panel remove tool as the pry bar. They go pretty easy with a little leverage.Speaking of the sleeves -- do you need to remove them from the motor to add the paste? How do I do that? Do I just pull on those springs?
Three of those threaded inserts in the drive unit are compensating, which means they slide within the bores to make up for frame tolerance. Removing, cleaning, and either using grease or green loc-tite on those when reinstalling should prevent any further creaking from the drive unit.
