Appreciate the effort
. Hopefully this solution is successful and can be applied to other motors as well.
Just a few questions regarding the Bosch Gen4 CX bearing seals??:
-Would this replace the current bearing seal kit available from Bosch or would it be an additional component (if you know what I mean).
-Are you developing a better crank shaft bearing that would prevent water ingress?
I understand if you’re not able to provide details (patent reasons), but I look forward to any improvements for the water ingress issue on this motor. These motors are getting better each year and you’re probably seeing issues that the engineers overlooked or never expected.
On a side note; I’m probably the “poster-boy” for motor abuse, but I’ve been lucky for the past 4 years. I try to service what I can but it’s difficult to avoid the daily washing, occasional submerging, types of weather, etc, but I make a conscious effort to maintain correct cadence and not “clunk” the crank. Not sure what else I can do?
Anyways, I’m glad you have a “rescue-room” along with possible solutions.
