Yep, mine goes in the backpack too, it's fine for me.Not the answer you are looking for, but I carry mine in my backpack. The weight isn’t bad at all. I couldn’t imagine putting the extra battery on the frame somewhere.
Thanks! The shock is on and fully pumped up. My excuse is, my previous bikes were hardtails and this is the first time I've tried to do this.This may sound obvious but …did you completely release the pressure from the shock (or coil, if you use one)?
You should be able to gently remove that pivot axle by lifting the rear triangle slightly (unless it’s frozen in place by rust or dirt).
You need to remove both the linkages (aka side triangles), then you knock the axle out with a driftHow do you get this axel out of the suspension? I removed the side bolts and the set screws but can't tap out the big axel circled in red below. It looks like the I might have to remove one of the side triangles in the green circle.
IMO, this may not be necessary to remove the main pivot bolt or axle. (Unless you’re doing a complete bearing/bushing servic). On most Trek full suspension mtb’s releasing the tension on the shock(psi) is enough to free up the pivot bolt/axle. This can be a critical point and sounds horrible when it’s dry or not working properly.You need to remove both the linkages (aka side triangles), then you knock the axle out with a drift
The diagram from the service manual shown above is wrong, the two bearings that the axle rotates on are not held in the linkages (as the diagram implies) they're in the frame, so you can't push that axle out without removing the linkages first.IMO, this may not be necessary to remove the main pivot bolt or axle. (Unless you’re doing a complete bearing/bushing servic). On most Trek full suspension mtb’s releasing the tension on the shock(psi) is enough to free up the pivot bolt/axle. This can be a critical point and sounds horrible when it’s dry or not working properly.
The chain guard may need to be removed also if you intend to replace those bearings.
When you remove this pivot bolt/ axle, apply enough grease to prevent water ingress and inspect the parts for wear Or corrosion. It can really sound like hell when it’s not working properly.
On my Rail I re-grease this area on a regular basis (or constant use, 1-2 times a year). My Fuel EXE doesn’t have enough kms yet…it’s too new.
I agree, the diagram is confusing. Releasing the psi to zero by removing the psi valve in the shock is helpful to remove any of these rear suspension parts.The diagram from the service manual shown above is wrong, the two bearings that the axle rotates on are not held in the linkages (as the diagram implies) they're in the frame, so you can't push that axle out without removing the linkages first.
You can see in this image of the linkage that the linkage has no room for the bearings, the bearings are in the frame. The others bearing, that the shock rotates on and that the seat stay rotates on are in the linkage, but the axle bearings are not.
Oh man! Chasing a creak or squeak sucks.Thanks for the help! I removed the linkages, checked that the bearings spin freely, lubed everything and put it back together but it still squeaks
When I had it apart, I moved the seat stays and the rear wheel pivots seemed smooth and quiet so I didn't take them apart. It looks like one side requires a special tool.
The Main Pivot is next in line for disassembly. I can pull it out without removing the chainwheel?
I posted on here a while ago about a creak that I had been chasing for months, I took the whole bike apart, cleaning, greasing and replacing bearings as I went, but nothing fixed it.Oh man! Chasing a creak or squeak sucks.
Loose seat post or saddle can cause a mystery creak. Headset bearings, proper torque, seated properly? Crank arms? Peddles?
I’m just spit-balling here but that lower pivot always seems to need attention.
There is a nut fitted into the frame that may remain in place …removing the chainring may not be necessary.…if you’re careful.
I thought that was the problem with my bike but yesterday I had the air can of the shock serviced but the creak is still there.I posted on here a while ago about a creak that I had been chasing for months, I took the whole bike apart, cleaning, greasing and replacing bearings as I went, but nothing fixed it.
In the end it turned out to be the air can on the shock, it needed unscrewing and the threads greasing. I'm not saying this is the cause of this creak, but it's actually not too hard to take the air can off and grease the threads, so might be worth a try.
"Hasta la vista, baby".My squeak is gone! A woman I know said it could just be dust. I was very skeptical (not just because she is only a woman -joke) but I hosed it off, rode it, and the squeak was gone. I thought maybe water got into the squeaking area and was temporarily lubricating it so I waited a couple of hours for it to dry and rode it again and it's still quiet. Maybe Mteam should add "Dust" to his list of things that cause a bike to squeak. Thanks to everyone who encouraged me to learn how to lube the suspension. That is good to know.
Good question. To be perfectly honest, I don't know where creaks go when they die. But, I can tell you this, there is no god."Hasta la vista, baby".
But where did the creak go?![]()
I’d wager it will be back.I just hope the creak is still dead.
I'd wager you are correct but so far so good. I did my regular ride today and it didn’t creak. If it ever creaks again, I will wash it one section at a time and then test for creak to narrow down the source. Once I find the source, I will have my results published in Scientific American.I’d wager it will be back.
I did like 3 complete rebuilds on my Fuel when I first got it, creak-hunting, it’s been quiet since. Free-hub, headset, cranks and pedals were the the main offenders on mine.
… I had already seen both - evoc backpack and a beer can tube that is NLA.Somewhere on this forum amongst the 3000+ threads, someone has talked about this & mentioned a backpack that will carry a spare battery and also a top tube bag. You should be able to find it with a search.
I don't know if you found the creak. I don't know if you want to. If you are looking for the creak I can tell you we might not be able to help you.I'd wager you are correct but so far so good. I did my regular ride today and it didn’t creak. If it ever creaks again, I will wash it one section at a time and then test for creak to narrow down the source. Once I find the source, I will have my results published in Scientific American.
Do you have some Special recreational drugs up there in BC? That is where I was born by the way, five days before Wayne Wong and in the same hospital. Still, I'm not Wayne Wong.I don't know if you found the creak. I don't know if you want to. If you are looking for the creak I can tell you we might not be able to help you.
But your creak may have very particular set of skills. Skills it has acquired over a very long career. Skills that make it a nightmare for people like you. If you find the creak know that'll be the end of it. It will not haunt you, It will not pursue you. But if you don't find the creak, It will look for you, it will find you and it will pursue you.
Good Luck![]()
Yes. He skies at the ski areas near Lake Tahoe and I see him occasionally.Wayne Wong? The skier?
I smell the occasional aroma of fun-smoke while I’m out riding.AND… I may have overdosed on chocolate before …I blame the Swiss.Do you have some Special recreational drugs up there in BC?
Can you provide a photo of the head? I believe the hex bolt is a bigger one since it was machined down?Sorry dont have any drawing. Best way is to take bike to local garage and ask them to make for you custom size bolt. They will measure bike and shock bushing and will make one for you without gap. We took one size bigger standard stainless steel bolt and made it from that one.
Orignal shock bolt head is with hex for 6mm alen key. Bolts we made custom ones from where bigger - M10, so have head for 8mm alen key. You machine down just outer diameter, you dont touch hex.Can you provide a photo of the head? I believe the hex bolt is a bigger one since it was machined down?
Can you provide a photo of the head out of curiosity? Just talking to some guys that can do this job but a visual of how much gap between hex thread and edge of bolt would help.Orignal shock bolt head is with hex for 6mm alen key. Bolts we made custom ones from where bigger - M10, so have head for 8mm alen key. You machine down just outer diameter, you dont touch hex.
