Hi,
I found that the other forums i used to be at have less traffic than this one, and this one has a Relay manual which is nice. I thought I'd just compile the list of things that may be useful to Relay owners (as a new owner of that bike myself) as reference. Files attached in case things are down (Transition's site tend to be down often usually for a day or two, in my experience...)
Shock tunes
DHX on Large PNW (from myself)
Float X on GX AXS (size unknown, from 1050st@ on mtbr)
Software
Torque settings
Frame specs
Modifications
Stronger battery door latch (from me)
Replace the weak spring by a rubber o-ring - these take much more force than any spring ever will. Tape the frame around the gasket area to improve grip. Result: door no longer moves/no noise during DH riding on fast and rocky terrain.
Shock tunes
2023 SERIES DHX TRUNNION 2POS-ADJ
Part number: 960-04-212
Description: 2024_23, DHX, F-S, Cr, 2pos-Adj, Trunnion, Transition, Rapido PNW, 205, 65, 450lbs/in, CMSSAL001, PRMAL001, Rezi LLB3, No Logo
2023 Series FLOAT X 2pos-Adj - 2024_23, FLOAT X, P-Se, A, 2pos-Adj, Trunnion, Evol LV, Transition, Patrol, 205, 60, 0.7 Spacer, CMSSAL001, PRMAL001, Rezi LLB3, No Logo, Neutral Logo
Software
- RIDE60 firmware page, Toolbox software (req. to update)
- Fazua mobile app
- Current fw 009
Staff assembly manual(from frank_doktor@ here, thanks!) [edit: it's been deleted, see attachments instead]- Relay support page
- Transition's Decals file
- Transition's quickstart guide
- Fazua motor assembly, motor manual
Torque settings
Frame specs
Modifications
