Mine is. I like it.Have an itch to move the bike to 170/170 29er...
Who has seat time like that? dont think its a huge change to Geo...and more travel is more betta
Really happy with the bike after nearly a year it's probably more bike than my riding justifies but gives me confidence. I have XO PNW.Loving the bike so far. The 38s need a bit of fettling to get them tuned just right but I find that's always the case with Fox factory kit.
First time with TRP brakes and they've been great, lots of power and easy to modulate. I am looking at a 50mm stem rather than the 40mm just to give a little more reach.
Super stable in the air and a great balance between planted charging and still being easy to throw around.
Also picked up a brand new air shock cheap and have some lightweight 29 wheels from my HT so can easily convert it to a lighter 29er build for XC/trail rides.
The battery lasts surprisingly well, especially compared to our Forestal Cyon.
I have been concerned about hitting the motor on rocks. Well the other day I smacked it hard enough to dent the cooling fins on the bottom of the motor. It sounded horrible thought for sure I broke it. Motor is fine it just looks bad now.
Still loving the bike. It handles good, tows other bikes great and the battery last long enough for the rides I want to do.
My only complaint is I updated the motor. I had to blow out the usb port with compressed air. It was full of dirt so it wouldn’t connect.
Up a fire road on a normal bike its a heart attack about 1,200 vert in 1.5 miles. Rider behind me ways about 140lbs. Tows really good towing in all colors but keep it in the two lower settings unless we want to show off. My riding partner has a Specialized Kenevo SL he can't keep up with us.Interesting that you Tow with the bike- how does it fair? Assume you're in Pink? how steep of an incline are you towing and how heavy?
i tow 165 and 210lbs riders ex. bikes + my 180lbs and im usually in pink. tow works but its much slower than full power bikes.if both riders were like 140lbs i imagine its a lot faster. 165 to 210 makes a huge diff for example - i can use blue sometimes with the 165 guy but not really realistically with the 210 guyUp a fire road on a normal bike its a heart attack about 1,200 vert in 1.5 miles. Rider behind me ways about 140lbs. Tows really good towing in all colors but keep it in the two lower settings unless we want to show off. My riding partner has a Specialized Kenevo SL he can't keep up with us.
I tried out both, the BBT 59.3 and the fazua tool.Btw, which tools are required to remove the cranks/Chainring? Parktool BBT 59.3 respectively Fazua lockring tool I guess?
I changed my cranks and used a bbt - it was okay just needed to be careful. I did find the 8mm hex bolt was super tight!I tried out both, the BBT 59.3 and the fazua tool.
Fazua tool is much better, the BBT is not deep enough, possible to use it, but care needed not to slip. Also the fazua one can be used with a ratched tool and with a pipe wrench. The bbt only with ratched tool (3/8“)
What’s your height and what size did you go with? Thinking of doing the sameI just picked up a carbon gx axs build myself. Swapped it over to mx, swapped the 36 for a 38 grip x2. More mods and fiddling to come. Coming off of a long shocked, cascade link mullet orbea rise with 160/160 that's done tons of miles. Stoked to ride this thing and super stoked that it's the same geo and fit to my nomad 6.
I'm 6'2", 33" (ish) inseam and 175lbs. I bought the XL, it's definitely a large bike, but fits me pretty well. It's nearly the same geo numbers as my nomad 6 which fits me like a glove. I will likely put a works components 5mm reach adjust headset in it to shorten the reach down to 497ish so the fit is the same as my nomad just for consistency of feel/font center / rear center ratio on my hardest hitting bikes.What’s your height and what size did you go with? Thinking of doing the same
View attachment 142848Thought I'd throw an update here, I have three rides on the new alloy PNW Relay (I swapped the coil for air) and so far its been a better experience than the Carbon one I had when they first released. First the new software has eliminated the weird "disco lights" problem that used to happen on power up and no power cut outs so far, the bike came with the updated control ring so that was nice too. The bike is 4.5 lbs heavier than the carbon with the same parts but when riding its not even notable. I packed some foam in the frame as advised here so no cable rattles, and the battery door fits so much better. The last thing I noticed is the bike is much quieter, the carbon one sounds like a plastic trashcan thrown down a fight of stairs when descending. If you are on the fence of buying alloy or carbon I'd say go alloy. Time will tell on the motor reliability but so far its been nice to get back on the "e-Spire"
That one you linked is for a straight 1-1/8" steer. You want one for a tapered steer tube. This would be the one Reach Adjust ZS56-EC56 - To Suit Tapered Steerer - 5mmI'd like to do this same headset. Could you point me in the correct direction as I have no idea what I'm looking for?
Thinking it's this one: Reach Adjust ZS56-ZS66 - To Suit 1 1/8" Steerer - 5mm
Thanks.
for what it's worth I am 5'8" and did a test ride on a medium and it fit me perfectly (though I have a relatively long torso for my height).I am torn on sizes. I like the reach of the large and the wheelbase of the medium. I am 5’9”.
Yeah sadly the first one was cursedI'm so confused. Didn't you take a bath on your 1st one because you decided that you needed a full power e-bike?
Loose cables inside? On the carbon ones these get crazy loud.Guys- looking for your sugggestion on a "Clack" that has developed on my Relay
Typically happens on the bottom of rolls and hard g-outs
I cant define it is derailleur slap or if its coming from other spots, that I can eliminate
List of possible common spots that Im going to check
- Lower Pivot Bolt and flipchip - Checked and added loctite
- Upper Shock Bolts - Checked
- Float X shock -
- Motor Bolts
- Anything else?
