Giant E+1 pro free hub issue. No more well done Giant!!
minty15389
morpeth
I’ve just had my bike returned and first I must say how professional Giant Newcastle have been, identified problem listened to all my issues and fixed the problem.
They contacted Giant and told them there was an issue with the free hub and they didn’t want a like for like replacement, Giant then instructed them to source a upgraded hub, they did and fitted it all within a week,
Haven’t bean on it yet not going on it till Sunday but fingers crossed that’s the problem sorted!
Haven’t bean on it yet not going on it till Sunday but fingers crossed that’s the problem sorted!View attachment 10875View attachment 10876
Sorry, not mechanically inclined...
From the photos it seems the entire axle was replaced - not just the freehub. Is that right?
So the wheels had to be re-spoked?
Great stuff i need to go back my rear hub cone bearings have gone loose again ( fixed two weeks ago)
Gutted I have had the same issue but I am still waiting for the replacement and I have purchased a new hope wheel from giant
Yep rear wheel is cone bearings... if it keeps failing i will seek an upgrade
Cone bearings work great in the right applications and when adjusted properly, old Campy road wheels are a perfect example for that. They spin super easily. Sealed cartridge bearings, while having more drag because of the seals, are more weather proof, because of the same, and are almost impossible to overtighten in most wheels. I only run into cup and cone bearings in the cheapest of bikes these days. I'm very surprised they're on yours, since a decent cartridge bearing hubset is also cheap.
Giant are doing the same for me. It will be another week before i get the bike back. Was in formed by LBS that upgraded Giant hubs are about 6 weeks away and the internals have been changed from alloy to steel. It will be interesting to see if Giant recall the bikes to change them out.
Only 1 ride in on my trance but thinking of replacing the rear hub before I get problems.
Could you use the same spokes and rim for the Hope hub rebuild Minty?
depends on which hub you buy, if its a straight pull hub then no. but most hubs out there have 2 styles so you should find what your after. seems a lot of people are going for the hope hubs
i was told by giant that they replace all spokes for new ones on the rebuild, every thing working as it should and loads of rides in since the replacement!
    672K
