Levo Gen 3 Galfer purple pads E-BIKES G1652
Titaniumdean
15
Hi, ive tried using these to replace my SRAM OEM ones, the SRAM go in as you would expect ,but the bolt won't seat in the last pad hole to tighten on the Galfers, am I missing something?, they are the I believe, the correct pads, put the original back in no problems at all
Mik3F
139
129
Middleton
I had similar issues with a set on my rear Guide RE caliper
If I did manage to get them in they were super tight and didnt allow the wheel to rotate
A different brand of pads went in perfectly fine
I need to replace the rears again at the weekend so will be trying another set of Galfer pads I have
Semmelrocc
247
607
You probably purchased the wrong pads, I would guess. If you have Guide RE or Code R brakes, maybe you accidentally ordered the Guide R version? They look similar, but aren't compatible.
Mik3F
139
129
Middleton
I 100% know I purchased the correct ones
They went in the front caliper just fine, I did have to sand the pad down a little to stop them rubbing
They do look a little thicker than the standard SRAM ones to my eyes
Polar
268
365
Norway
Which SRAM brakes do you have?
The one you bought is for Level so if you got Code you got the wrong one
Semmelrocc
247
607
I recently installed these exact pads on my Guide RE caliper and had to be extra careful to push the pistons fully back. Works great for me (on used SRAM Centerline rotors at currently ~1.7 mm thickness).
Titaniumdean
15
Ok, so I have Code RS and I got these, so not sure now
Dhd12
41
16
Almería (Provincia)
You should not sand down the pads. Push the pistons back into the caliper. If you are unsure what to do, which it sounds like visit your LBS. Brakes are important
Mik3F
139
129
Middleton
I know exactly what to do, the pistons were fully pushed back into the calipers, like I do every time I fit new pads
These pads were just thicker than the usual ones, maybe down to a manufacturing defect, and they are currently working just fine in the front caliper
Dhd12
41
16
Almería (Provincia)
Sorry for being presumptous . Never had a brake pad on a bike/motorcycle/car that didn't fit in in over fifty five years of maintenance. Did you measure it before you sanded it down?
Mik3F
139
129
Middleton
I didn't to be honest,
I am changing the rears this weekend with a fresh set of Galfers so will see if I have issues and measure them if so
Need fresh brakes for Dyfi
ebikeZA
286
142
Cape Town
I find that I need to bleed the lever to make more room to fit them. don't know if its the right things to do, but it seems to work for me
I undo the bleed port at the lever and let a few drops leak out and then tighten back up... seems to work
Titaniumdean
15
So just an update, replaced caliper , got for an amazing price, bled twice, wasn’t happy with the first and pads fit a treat, we are all different but I much prefer XTR brakes from Shimano than the SRAM codes, I prefer a really firm initial bite with not too much lever travel, SRAMs are too well modulated for me , thanks for all the replies 👍
Polar
268
365
Norway
SRAM Maven eats Shimano for lunch
527K
