Wireless dropper question...
MOTO13
Elkhorn, Wi
I am considering the Reverb AXS dropper. But, what do you do with the cable housing? Let it hang there? Remove it?? I am a bit leary of removing it in case the new dropper has issues. And, if you want the cable dropper, how difficult is it to re- install a new cable and housing in a Trek rail? Love the idea of the wireless dropper, just some concerns.
One of the reasons I installed the AXS dropper and derailer was to reduce the clutter of cables in the cockpit area. I removed both cable hoses completely which also cleared up the rats-nest in the motor compartment.
Re-installing the cable hoses may require that you drop the motor, loosen bulkhead and clamping points, and re-thread the cable thru the rear triangle and head tube. It’s not really that difficult if you have the time and right tools.
There is no real weight savings by installing the AXS system(s) but the quality and reliability was noticeable to me. My Fuel EXE will soon have an AXS dropper.
Do you favor one over the other? Meaning, if you were only doing one... the wireless dropper or shifter...which would you choose?
Interesting...fairly simple to install or were there things that you didn't expect that made the job difficult?
Good question. I would choose the AXS GX Derailer. IMO the AXS dropper is a luxury.
I use the AXS GX Derailer with the Shimano cassette and HG chain. (It’s a hack), but this combination gives me the best of both worlds. (Lower guide wheel needs to be changed).
Really easy to be honest, hardest part may be removing the existing shifter cable
Mine is stuck somewhere in the frame so has been cut flush at the rear and an inch above where it enters the frame, although you cant see it as its covered by cable tidy
Ok, I'm kinda dumb about this stuff...I have a Gen 4 Trek Rail 9.8 XT. It has the Shimano 12 sp XT deraileur-M8100 Long cage. How do I know which AXS wireless shifter model to choose to be sure it will fit my bike? I mean, it's a Sram deraileur and a Shimano drive. I could ask the people when I buy it, but let's be honest...do they even know for sure?
Regarding the Reverb dropper; my medium Rail came with a 150mm Bontrager dropper. I needed/wanted more so I installed a 170mm axs Reverb. I carefully measured, for fit, before I ordered the Reverb. Removing, servicing or adjusting the Reverb dropper is easy. The seat angle adjustment is nice also 👍🏻.
Self servicing the reverb is very easy, however Sram did replace the “O” rings under warranty.
Combining a Sram AXs GX derailer with a Shimano cassette and Hyper-Glide chain is a hack. There is a YouTube video available which shows the entire procedure. Like I said …it’s the best of both worlds. I’ve been using this setup for almost three years now. The lower guide wheel may need to be changed.
The problem I have with this setup is; too fast, too quiet and too smooth. 🤷‍♂️
I just spoke to Aidan at WWC...they have the AXS GX model which he recommended for my bike. I assume the chain will remain the same length and not need to be shortened??
There’s a number of factors that determine chain length when you start adding new drivetrain components. (Cage tension, “B” screw, chainring size etc.) if you’re not comfortable with this step have your LBS help. They can insure that the operation of your setup will be as smooth as possible.
I love my AXS dropper, it’s an expensive luxury but it is so nice, I wouldn’t go back to cable by choice.
I just whipped the old cable out and stuffed it in the “shite drawer”
Have you plugged the holes - if so what's the best and easiest way to do it without getting the stock plugs?
I was going to ask the same thing. Gotta plug the holes if you remove the cable housing I'd think???
Where the cable exits the top tube, near the headset, there will be one small hole. There may be a plug available but I just, carefully, filled the hole with clear bathroom silicone. Keeps any water/debris out …and it’s all I had at the time. 🤷‍♂️
I guess that’s a bodge fix…but I haven’t thought about it since.
Me and my mate both run axs gx with Shimano cassette and chain. Took 15 mins to install and is super smooth. Neither of us needed to do anything other than adjust b tension and a couple of adjustments on indexing with the app. Would never go back. Also just added the axs dropper. Nicer to use than the original 170mm that came on the bike but just did it to remove the cable at the bars and treat the bike to something nice :LOL:
Got both dropper and derailleur on my cube stereo that came with Shimano XT drivetrain. Again nothing else needed but setting up the new derailleur.
I tried to pull the battery tray out for access but in the end I just grabbed the shifter cable at the headset and pulled! The cube dropper cable comes out of the side of the down tube and into the seat tube. I had to pull out the bit into the seat tube first then pulled from the headset again. I imagine it would be a nightmare to get them back in but I’ve got no plans to.
Only problem I’ve had is trying to find blanks for the holes. Black electrical tape does the job though!
This plug sold out for the last few years. Suppose it's a better and cheaper way to fix it but unsure how important it is.
I was looking at Sram transmission and it seem like the most affordable way if you currently have a 12 speed drivetrain is to purchase a derailleur and shiftier separately.
We're talking about the round hole through which the housing goes? Get a tube of black silicone RTV gasket sealer. Get the quick drying if you can. Put a dab on your finger, and rub your finger over the hole. A little goes in the hole, your finger wipes it smooth, and it's not even noticeable when you're looking at it. If you change your mind in the future, you can poke out the silicone plug. Easy peasy.
On my Fuel EXE I have the T-type AXS derailer which is powered through the main battery. I was surprised how smooth it was while shifting under load. But I don’t like the Pod controller. My Rail has the paddle shifting for the AxS derailer. It allows shifting with thumb or index finger.
A bar clamp type seems to give you a bit more positioning options, but the match-maker is fine.
Dont forget to buy a battery and charger.
High Rock Ruti
Best dropper I've ever had, significantly better than cable, significantly!
Warm Regards Ruti
The SRAM transmission requires the whole drive train be replaced. It works as a set together (chainring cassette chain derailer). You need the chain that comes with it as it is flat on top.
    Join 43,208
