Levo Gen 2 Help choosing between air or spring shock
eabmex
Guadalajara, Mexico
Hi, the shock on my gen2 Levo expert got damaged when the shop tried to service it so now I am looking for a replacement.
The local Rockshox dealer is trying to convince me that the best option would be the Super deluxe ultimate coil but I am no sure if an air shock would be a better option since I do mostly trail riding and do not do huge drops or jumps.
Anybody sharing their experiences would be appreciated.
I switched to an EXT coil on my gen 2 because I thought it would give me a smoother ride on the washboard tracks I usually ride. And it did. Not as big a change as putting the Smashpot coil in my fork, but it did help.
Guys typically point to the not-very-progressive Levo rear geo as the reason to avoid a coil spring, but some shocks can fit a variable rate coil. This give you the best of both worlds - an increasing rate spring like an air sping and the lower friction of a coil spring. My EXT is not one of them, so I'm running a fixed rate spring.
I don't ride trails that "hit hard", so the only time I've bottomed out the rear suspension is when I do a big preload for one of the huck-to-flat drops where I usually ride. That feels like bike abuse to me, so I haven't done it very often.
I also have an ext e storia on my Levo and it’s a huge improvement over the stock x2… which was so bad all around that fox is replacing all of them with the new model.
I'll go the opposite :)
I swapped out a DVO air shock for a Cane Creek Kitsuma, faffed around for ages with different coils, progressive springs etc.
I just couldn't find a set-up that felt as good as the progressive ramp of air for the last 30% of the travel.
The first 30% of travel was marginally smoother and tracked better with the coil but any big hits/drops and pushing out of fast corners I just got on much better with the air so went back to the DVO Topaz.
The Jtech suspension guys that were helping me did mention that riders over 80kg can struggle to nail a coil setup on a levo with the linear curve. I'm around 85kg
I didn't want a coil because I thought air could be more fun. But after going with a long link on my S3, the X2 made contact with the frame, so I quickly put on an Ohlin's coil, and boy do I love it. The bike is so planted. It doesn't have quite the same pop, but it climbs insanely well now up tech and is on rails going downhill. On such a heavy bike, I find the coil suits it very well.
I just ordered the Super Deluxe ultimate coil, I read that the hydraulic bottom out is great for the linear suspension of the Levo.
Will report back once I try it.
Thanks to everybody for their insights, it helped to put to rest the agony of the decision.
I put an Ohlins TTX on after my 3rd air shock failure. This was pretty much my experience too. Makes the back end feel track the ground more closely.
    Join 43,147
