Anyone blowing through speed sensors?
Plummet
Flash Git
New Zealand
I've got the mini rotor magnet speed sensor. The first one lasted 6 months and just stopped working.
Now 3 weeks later ive blown through a second one......
Hmmm. It's going start getting expensive if thus keeps on happening.
Yup, same problem.
When I ride too fast I burn them out. There's too much harmonic wave destruction as the magnet passes the hall sensor when you're consistently over 80kph+ . It's like being hit with an electronic sledgehammer.
You can either strip the sensor and remove 90% of the coils.
Move the sensor to the outside of the swing arm, or possibly under the saddle depending on your speed.
Or, I found it easier to swap to a pin head magnet.
Yup, same problem.
Do you have a pic of the magnet your using?
No issues here on Bosch Smart system. I don't even know where the sensor is on my Rail but I presume the rotor :ROFLMAO:
I'm thinking that it might be the pole routing of the sensor. It was floating close to he rotor, could easily be caught by a stick and or vibrate onto the rotor.
I've gone sneaky with this routing
I've gone sneaky with this routingView attachment 134575
That sensor looks much bigger than I expected compared to seeing a picture of one.
I'll be buying one soon if my voima ever gets delivered.
Why did you swap away from the rim magnet sensor? 1300 miles and no issues on my Voima with it.
I can tell you why I will be doing it. Going mullet so the sensor will be further away, plus for possible future speed modifications.
Same. I specced the rotor magnet option from New.
The mount that Mondraker use is much nicer than the crappy Bosch 'P-clip' style.
I'm wondering if it's rattling around and causing the failures.
Also, are your wheel bearings good and it's not the disc magnet hitting the sensor?
Bearings are good. But it's damn close. The one sided pole clamp is pretty average so likely it might be hitting. I'll do some closer inspection
What is the white stuff on the sensor??
The "P" clip that holds the sensor has a groove in its centre, into which the shoulder midway along the sensor fits, such that the sensor cannot move. This means the sensor can only be properly located into the "P" clip by opening the clip, installing the sensor and ensuring the groove and shoulder line up. If that has not been done the sensor will move and if it moves more that a bout 5mm it will cease to work.
    670K
