Gen4 CX wont power on
eTrax
USA - West Coast
After my last charge I went to power up and the Kiosk 300 display flashes then comes up to this screen and powers off.
I checked all connections and disc/connect the battery.
Any recommendations?
Gen4 CX Race
Mini-Remote
Kiosk 300
I might be wrong but are you checking that the display is completely docked, I ask this because I fitted my new stem the other day and my Kiox display did a similar thing, it turned out that it wasn’t fully pushed into the mount, might be worth just checking mate 👍
I dont understand!! Kiox 300 is merely a slave screen working off a controller. you list a bove that you have a mini remote and Kiox 300.................neither is a controller..............so where is the controller. There are only 2 Bosch controllers for the Smart System................a LED Remote, or a "System controller" which is top tube mounted.
Gen4 CX Race
Mini-Remote
Kiosk 300
That's a crestline isn't it. Mine did that you will have water ingress behind the kiox and on your terminals mate.
On Crestline RS, controller is located bottom side of top tube.
This ended up being the issue. Some micro corrosion on battery plug.
I cleaned up connections and it started normally.
I let everything air out then resealed the kiox and cable entries.
Has been good for several rides now.
Was it just doing it when charging on the side of the bike. Or the battery connection inside the bike.
