Riser bars?
ajtkiwi
new zealand
I have a stock 17 levo alu comp and really struggling with steep descents.
Feel like I’m going to go over the bars and did before Xmas....broke 4 ribs.
Even off the seat and set back I’m struggling....prob a bit ginger due to the prev crash and technique (work in progress) was wondering whether higher bars might give me a better positions and help with confidence?
possibly. as might a shorter stem but be aware the flip side is less weight (grip) on the front wheel until you compensate withy position/weight placement.
Possibly a silly question, but are you sure it's not too small a frame for you? If the head tube is too short it will push you closer to the front and give you the pre-otb feeling.
What size levo is it and how tall are you?
It could be a possibility to try and run a 29" front wheel, it will slacken the head angle, raise the front around 10 mm and give better roll-over capabilities. Downside will be while going back uphill with less weight on the front.
Karsten
@Dax has asked the question already but assuming all is correct regarding bike frame size have you had any formal MTB skills coaching? As silly as it sounds doing a "One on One" MTB skills session with a suitably qualified and experienced instructor will probably sort any issues that are affecting your position on the bike. They'll be able to look at your position on steep descents, climbs, cornering etc. and make the necessary adjustments to put you in a balanced position where you are in control of the bike and probably teach you some drills to help you make these positional changes second nature. If there's still a need to make adjustments to the bike cockpit they will be in best position to give advice specific to your needs.
It’s a large and I’m 5.10
Good call, I definitely need something like that especially after my spill
I suggest getting a dropper post. It makes a world of difference. I would not ride a bike without one for the exact reason you posted. Without one I feel like on any descent I could go over the bars. For sure, technique can compensate for this, but the simplest solution I found was to put a dropper post on every bike I own.
That size is probably spot on for your height. I'm 5'9 and at the lower end of the spectrum for that frame size.
Yeah if the frame is too big, you’ll be stretched out too much with weight forward.
I’d try a shorter stem and or riserbars. Riser bars can be rolled back slightly too. Might pay to get a proper bike fit.
Could also be compression dampening making your forks dive to much into their travel. Try stiffening them up a bit so they don’t dive as much. Only a short term soloution if you got too much weight forward.
I’m on a large frame and I’m 6’1”, only problem I had recently was wen my forks decided to only give me 130mm instead of 150mm travel. The meg air spring was not equalising with the positive and holding pressure sucking the forks down.
cheers guys! I do have a dropper post fitted and use it always when going down steep bits
    Join 42,727
