Rail (750Wh) How do you remove the warning screen from Kiox 300
johnboy68
How do you remove the Avoid Distracted Driving warning from the Kiox 300 startup? I've seen it once. I shouldn't have to see it and press a button every time I turn it on.
Sounds like the annoying warning I get on the gps in the car. I wonder if the LBS can eliminate that screen. I still get the “needs service” symbol on the regular Kiox but the LBS has the ability to set the duration (500, 1000, 2000 etc) for the next service.
Did you figure this out, I want to turn mine off
Asked the LBS to turn off the "needs service" message on Kiox (not Kiox 300) but the message still came on at 2000 miles. Really irritating.
Its the same as the warning message you get on Car navigation systems. Each time you start a new ride you need to click ok
