Not sure that article has anything to do with any of us. Since none of has had to pay any duty. At all.
We are not buying ebikes.
Sorry my mistake, look like usa has zero tax on bicycle frame from china. Then i will definitely declare full value and insurance for ir. Just need to notify sender to declare it stated you will be responsible if any tax happens, usually they under declare it because of tax reason.
That is not uncommon. You pays your money and makes your choices.
Good news. A gentleman just drove up knocked on the door and said I think I have a bike frame for you. It was delivered to the wrong address, 30 miles away and the guy was kind enough to drive all the way here to return it to me :)
I was just thinking that before I read your update. Glad you got it.
48v 480wh
I paid my deposits since September until December only able to shio out cause fram shock mount positions mold mod. Then special request for T800 carbon upgrades and wait another few weeks.
Did someone do a linkage and leverage ratio curve with V1 suspension dynamics? We need that on V2. I would love to be able to swap in a coil for park days etc.
Page #3 or #4 of this thread. Thaeber, our resident mechanical engineer, did the calculating.
Hi all.
I need some help.
I'm mounting my own cef50. I have one problem.
I buy a Shimano rotor with integrated magnet. But, if I spin the wheel I get 0 speed.
Anybody has the same rotor working?
Any help about troubleshooting this problem?
If not works I will have to buy a centerlock magnet¿?
Regards
Hi all.
I need some help.
Regards
I have a bolt-on rotor magnet. Check your sensor mount. Trying twisting the sensor and/or moving it to the other bolt mount on the frame.
It wasnt 1:1, it started around 3.x. and ended around 2.x, with roughly 32% progression, which says the leverage curve progression would take kindly to coil shocks, and actually you would need to run high volume no spacer air setups. Do you guys have a hard time using full travel?
Sounds good. I couldn't remember...brain fog from recent illness I guess?
Got air 210x55 (MegNeg setup). No travel spacers/bands. No probs on full compression.👍
Hi all.
I need some help.
Regards
Hi all.
I need some help.
Regards
No problem with magura rotor and magnet. also tested with magnet provided with the frame. have you 2 sensor fixing holes on your frame ? have you positioned the sensor in front of the magnet ?
Exactly. I used an average ratio of 2.5 to calculate additional travel if You overstroke the shock, not 1:1. TC is using a RS with MegNeg, the bigger air volume is almost like using a coil shock. And he‘s happy with it, so I think a coil would work good as well.
Sorry I'm sick, so not thinking straight... Maybe the new Vivid Air next?
Thaeber have you seen the V2 frame?
I used an „old“ Vivid air with my E10 and it was a very very good shock, coilish 😊 and plush. If You get a good offer, give it a try!
Ha thanks! Better to go new! But it looks like the new Vivid ultimate'23/24 has too big of a E2E for my risk level.
Oh wait! I had the wrong spec page. There's a 210 x 55...perfect! I might try one next year!
But wonder CEF50 V.1 will fit it. Peeps had probs fitting the Fox Float X2. So...maybe not!🫣
    Join 43,139
