I still don't understand what that device is used forWait till you get to my age; you’ll forget what you bought it for.
lol. Once you tweak your back. Your days are numbered. lol.I still don't understand what that device is used for. How old are you? I just want to know how long I have before I need one!
Glad you've got a photo to remind you what it looks like new, because the cassette won't look like that after 50 miles!!After having issues and issues with AXS components, went to my local bike shop to get a full X01 mechanical drivetrain installed.
Shop did XX1 cassette & chain for the same price which was pretty nice.
Only took a picture of the cassette.
What issues were you having with AXS?
New brake day!! Yey! After getting rear through it wasn't long enough as they are used brakes but very little, so new house required, all done though and routed rear hose through R/H side of frame instead of left which it comes stock, that bit took the longest to do. All bled and new rotors, had a few blasts down the road to bed in a bit but needs more. Already feels 10 times better than the code R's, should have more confidence in them.
220's on the front, 203 rear
Oh and a little something installed in here to make use of the increased braking perf.
There hard to see but on fronts they are about 2mm to inside of caliper front and back, will check again in some daylight as they were done in the garage at night. Our dark UK evenings do nothing for installing and testing new gear, PITA, roll on springPads look right on the edge of the disc on the front (compared to the rear), not overhanging a little are they? Just thought I'd point it out. I'm sure it's fine, just looks like a lot of untouched disc area.
And the wrenches are for to adjust the ankles?
Chain lookin good ! Waxed ?I upgraded my Rail 5 - 625 wh, Ohlins coil and Zeb. Superbike all of a sudden.View attachment 130037
Not waxed, I use Finish Line Ceramic/dry lube - seems to work fine around hereChain lookin good ! Waxed ?
So wax ?Not waxed, I use Finish Line Ceramic/dry lube - seems to work fine around here
Finish Line's Ceramic Wax lube is an advanced, wax based bicycle chain lubricant that ensures total drivetrain cleanliness without the distance compromise that other wax lubricantsSo wax ?
Did you buy them online, what was the returns process? How did you prove this was just incorrect B tension etc?Had to warranty a Reverb AXS two times and GX AXS two times also. Reverb is just a mess own it's on own by design and GX AXS had the parallelogram come loose (bushing play) causing poor shifting or ghost shifts. Their warranty is pretty good however as they send new components in retail boxes most of the time.
Almost switched to T-Type, but went back to cable instead for peace of mind and reliability.
WaxFinish Line's Ceramic Wax lube is an advanced, wax based bicycle chain lubricant that ensures total drivetrain cleanliness without the distance compromise that other wax lubricants
Clearly works well whatever. I use a similar product in our dry dusty conditions ! You in SoCal or what?This stuff is considered wax? Wow, did not know. View attachment 130038
Either that’s a 55 gal drum or that stuff’s really expensive.This stuff is considered wax? Wow, did not know. View attachment 130038
No wax, just „wax like“ - Website Finish LineWax
