New Orbea Wild with One Up pump on bottle cage
What kind of sorcery is going on in this thread. Fouling? Struts? My beloved Wild?!?!
Forcing it to fit???
OP seek help and anger management. We are here for you .
Sort of…..
Yeah, those struts really do suck.
I sawed the mount that came with the pump so the remaining part was just a simple "U-shape" with the rubber strap. Then I drilled 2 new holes in it to secure it to the frame.
It obviously wont combo with a water bottle this way, but I'm fine with that.
The only pics I had laying around that shows the pump:
Like an inline mount which one-up now sell. Want to keep the water bottle though
Oh no, I hadnt thought of this, is there mounting holes on the underside of the top tube? mine hasnt arrived yet and i run a bottle and pump mount.
Isn’t there a bottle cage out there you can mount a pump to?!?! Seems it would be pretty easy with some zip ties.
my current pump holder sits under the side entry cage, so this means i'll have to get a new bottle cage and pump mount.
This is the way.
So I fitted the pump on the mount on the underside of the top tube. I didn't notice it had fallen off on my driveway until I had got back from my ride (glad I didn't lose it or need it) but now I need to re-stick it, I think because the frame is ceramic coated I don't think the pad stuck enough. (yes I had used the wipe to clean surfaces)
The pad part is concaved. Whereas the underside of toptube is flat. I held mine in place with zip ties whilst the glue in the 3m pad went off. So far so good
Top tip that!
just use a bottle rad adapter. On a,azon for £6.00 far cheaper than the wolf tools one. It moves the bottle mount up the frame and then you pump also fits
    672K
