... The only time the speed has a drastic jump is when I spin the wheel really fast; it’ll jump up to 14-16mph then drop drastically to 8-10mph(I’m told this is the Megabobra engaging, reducing the visible speed). It will also do this when the speed is gradually slowing down to around 4mph, it will then drop drastically to around 2mph then instantly spike back up to around 5mph then gradually come down to zero as the wheel slowly comes to a stop. (I’m told this is also normal as the Megabobra is “shutting off” to allow the visible speed to catch up to the actual speed)
Bosch must be referencing a different error code than the two error codes I’ve been getting because I just power off and back on to regain full assisted power out of the motor, as well as eliminating the error code on the Kiox. There hasn’t been a 90min ride time reset or emergency/limp mode.If they want, they can have full control over our ebike motor…, have a good relation with an authorized bosch dealer...
, "dangerous" ...
eBike tuning – illegal and dangerous
Technical manipulations to the pedelec are a safety risk. If an accident occurs, it may result in high liability costs and criminal prosecution. Bosch asks all eBike riders and providers to refrain from tuning.www.bosch-ebike.com
"The software of the Bosch eBike systems can detect whether the pedelec has been tuned by means of a sensor while riding. It then switches to emergency mode. Consequence: an error code in the display indicates manipulation and support is reduced. The eBiker can restore the original riding settings by riding the pedelec for around 90 minutes. As soon as the system returns to normal mode, however, the manipulation check will be repeated. After the third time, limp home mode can only be deactivated by a specialist dealer using the Bosch DiagnosticTool."
Just a thought, when the device transitions from passing magnet pulses straight through to generating its own pulses (or back the other way) is there a delay or a repeat pulse at that point? That might be enough to trigger the 523 error.
If that is the case, the magnet could not be strong enough when passing very fast against the reedswitch, not able to close…Went on another 22mile ride. I tried the small round spoke magnet with no luck, it triggered the same error code within a few minutes of the ride. I moved its position a bit and it triggered the same error code again right away. I reinstalled the black plastic covered cylindrical magnet that I used on my first ride with the Megabobra installed and it seems to work the best, but I still eventually get the same 523003 error code, sometimes followed by a 523001 error code. At times I am able ride 10, 15, even close to 20miles with this magnet, error free.
I’m curious if anyone has had success with the Megabobra with the programmed 1.6 / 32mph limit?? At this point I’m wondering if the Megabobra engagement and disengagement with the programmed 32mph limit setting is to much speed fluctuation and causing these sporadic error codes when using the cylindrical black plastic covered magnet?
On this ride my max speed was 32.6mph but if lowering the Megabobra max speed to 30 or even 28mph would eleminate the error codes I’d be ok with it!
View attachment 128042 View attachment 128043
Here the “signature” of a perpendicular vs // passing by magnet.
So the ring magnet is just a strong long N-S magnet, consisting of 2 separate n-s
N-S||•||N-S
Definitely give this a try. If the contacts in the reed switch are not facing the magnet they'll be pulled in the wrong direction as the magnet passes, ie not towards each other.The magnet that works the best so far, I’ve moved in different positions while on a ride. The only thing I haven’t done is rotating the reed switch to a different position facing the magnet.
Apparently I had to do a second update and now to 8.16.0 !Just did an update of my drive unit from 4.21.0 to
, will see how it goes
All went well
What reed switch and electric magnet coil are you using?Apparently I had to do a second update and now to 8.16.0 !
First quick short test run and all seems ok… (I am running at factor 2, easy to calculate)
Must e the location of the “programmable”, hall sensor…
View attachment 128298 View attachment 128299 View attachment 128300
Here are some more interesting patents I found.This one is interesting:
Method and device for checking the plausibility of speed data
I believe there is, as one of Bosch's instructions to commence walk mode (after holding the button down) is to tip to the bike to the side.Has anyone does a teardown of the gen 4? I'd like to see if there's an accelerometer on the board.
I made my own setup (MEGABOBRA: Bosch Smart System Derestriction for Rim Magnet - DIY Project with Support)Here are some more interesting patents I found.
Detection of sensor manipulation of an electric bicycle
Not Bosch, but a comparison on power used in air/rolling resistance, with hill climbing contributions stripped out, against expected power used for the sensor speed. Pretty much how I believed the Bosch system to work, until I saw that first patent (and the first patent gives enough wiggle room so they still could use that method)
Method and device for checking the plausibility of a sensor signal of a single-track vehicle
This one is by Bosch, it relates to detecting the gear ratios of the bike by looking at a histogram of wheel speed to cadence ratio. With everything working, there should be strong peaks in the histogram corresponding to the different gears.
It's more for detecting unreliable sensors than for detecting manipulation, but it could be of interest if a derestrictor were to switch between generated pulses and passed-through pulses. It could also catch out mode-switched derestrictors since they would look to the algorithm like they had two different sets of gear ratios, and the patent specifically mentions detecting the case where there were more histo peaks than physical gears. It is known too that the motor will throw an error if its programmed highest gear ratio is exceeded.
