Want to buy a Feedback Sports Scorpion stand for heavier emtb, thoughts?
713Fmhs
I'd like to buy a Feedback Sports Scorpion stand that will be used on both a Spec' Levo Comp Alloy, (53#) and a Tero 4X, (57#). The mfg data says the stand will support 50# max. I suspect it would hold a bit more but I wonder if there is a stand just like the Feedback that is advertised to support over 50#? I really like the design of this stand. Below is a link to the stand. I'd appreciate any thoughts opinions on this. Thanks!
Any luck with this working with the Levo?
Have used it for my DH bike and it's very good. It's a 2 piece stand and parts are tight together with one 6 or 8mm hex. Just glued the bolt with threadlock as it happens to get a little loose. I would guess it can hold an ebike but the structure could be better. You can always weld it even though you shouldn't have to.
    677K
