Bike cleaner recommendations
Don't get G-85 near the rotors or calipers!!!
On a serious note, if you do accidently contaminate your discs / pads, immediately clean them with pure acetone (not nail polish remover as it has other ingredients) and a bit of a 1200 wet and dry sand paper.
I do this regularly to remove containments, dirt/mud and brake pad dust. Brakes are still going strong and don't squeak at all 👍
I use acetone over brake cleaner as you can soak the wet and dry in it to soften it and if you shop around it can be bought for a fraction of the price of brake cleaner. Just avoid contact with painted areas.
Hi
I’m looking for recommendations for a good bike cleaner to clean off the winter mud and grime. I clean my bike once a week (it gets used 2-3 times a week always off-road) I’ve been using Muc-off but it keeps going up in price. I’ve been recommended fenwicks and have used it at a friends ,but any recommendation will be welcome.
Cheers.
Best one by far is if the wife does it for you.
All bike washes are a scam, just use water and a cloth or cheap auto wash soap if you really think you need suds.
D
Yes I use the cheapest car wash and only a squirt. I've even removed dirt when out on the trail on my own by peeing on the bike .Chains don't need that much attention unless your OCD and there's plenty of that on here.
Bang on this stuff👌😎
Bike Xpert Bike Cleaner | 5 litre (2 Pack) With Foaming Extension Hose | Fast Acting Bike Wash | Biodegradable | For All Types Of Bikes | Bicycle Cleaning | Ready To Use https://amzn.eu/d/6yn7Amo
^ Soapy water like Dawn diluted in water isn’t going to hurt anything. The most important part of cleaning a mountain bike is having the proper tools. There’s a couple of companies that sell sets of brushes, and it makes cleaning so much easier.
Hi
Cheers.
I use the Muc-Off product myself. There is anither product I use in wet/muddy conditions to help shed mud and make cleaning a lot easier as well: Amsoil‘s “Mudsliger” spray-on was developed for ATV market but is great for any mud activity, it doesn’t pick up dust and dirt like more oily products, stays on for 2-3 weeks.. I spray the underside of down tube, back of seat tube, rear triangle and rear pivot, shock link (do NOT overspray onto brakes/rotors). https://www.amsoil.com/p/mudslinger-amssc/
Hi
Cheers.
Hi
Cheers.
I went with fenwicks and so far I’m impressed.
Still fan of foaming before spraying with garden hose and mild brush:
Got a 4 l can of chemical guys honeydew. Use it in a foamgun (cheap aliexpress)for everything mtb motorbike, cars...
Great stuff, thick foam smells good and cleans good
yes, muc off is really expensive and it is again common alkaline degreasing it contains.
you can buy alkaline degreasing cheap in cans at e.g. motocross/enduro shops and then dilute it yourself. buy a 5 liter canister and you have so you can wash the bike all year for half the price than muc off costs.
Halfords cheapest car wash don't need to use much and will last a year at least and that's washing the car occasionally as well.
Well I use Aldi spray can bathroom mousse cleaner.
Wet the bike, spray foam on and leave it for about a minute then rinse off.
Seems ok and been using it for years
I've used fairy liquid as well . It's muddy sometimes but how clean do you want it. Same with chain 3 in 1 oil cheap as chips. Used that for 30 years probably.
I keep Dawn mixed with water in one of those weed spray hand pumps and have been washing my bikes like this for years. The only issue is Dawn is so good at removing grease you do want to go lightly and be careful where it gets into.
*I dont want to comment but I feel i need to*
*I dont linke GMBN but in this instance they are correct*
*Using home detergents is a really bad idea, just like using washing up liquid to wash your car*
*There is specialist cleaning products for a reason*
Not a bad video, but it's also clearly sponsored by Much Off. My takeaway from it is I do think I need to look more into a water displacer.
Dove soap, though is pretty bike-safe, and we use it a lot in the jeep world too, where we aren't worried about wax and finish. Used mostly on the undercarriage cleaning but I use it also in the engine area and will do a full jeep wash but normally only in the spring as a major clear to remove all salt from the Jeep.
I just use a brush and water. Not washing my bike is just not an option in Scottish Winter (or summer). Once inside I wipe down with a cloth and lube the things that need lubed.
Whatever bike cleaner you use, use it in a foam cannon, you get 100x the coverage. It’s amazing just how little you use.
I have a 24L container with a tap and I use the concentrate packs and dilute them. The 24l lasts well over 12 months.
Well that's as clean as it ever gets . Be clartit wi mud on Friday again as I'm going out . Then it will get a clean again on Saturday if its lucky. I dont clean in the dark anymore. . Demon foam this time don't need a lot . Quick brush of chain with 3 in 1 oil no expense spared . Check everything is lined up with the Verynear gauge . That's what I miss about the non Ebikes just a quick hose when I came home and as everything is still wet it's was easy cleaned. Getting lazy 😴 as I get older as well.
I occasionally use a muc off or peatys spray but that's since I received them as gifts. Otherwise I just use some meguiars gold car shampoo I've had for years.
    Join 43,277
