2manytickets
So now that I finished with all my upgrades and got the bike dialed in to my liking. Here are a few pics of the transformation.
A short ride is all it took for me figure out I would be pushing the fork past it’s limits. I noticed it would flex more than my Yari I had on my old stumpjumper and it didn’t have the plush feel of it ether. So I made the decision to swap the forks out.did you ride with the original fork at all?
Where's ya helmet ya nong lol
What travel did you maintain for the Yari? Was looking at a second hand Yari (which also came out of a Stympjumper) and thinking up upgrading it to a Charger 2 Damper as well as the Debonair Air Springs to around (170-180).A short ride is all it took for me figure out I would be pushing the fork past it’s limits. I noticed it would flex more than my Yari I had on my old stumpjumper and it didn’t have the plush feel of it ether. So I made the decision to swap the forks out.
I got a 160mm Lyrik on my Levo as well (swapped out the Revelations). I absolutely love it.I have a 160MM Lyrik on the way for my 2019 Base Levo.. hope it is noticeable.
me too, fantastic forkI got a 160mm Lyrik on my Levo as well (swapped out the Revelations). I absolutely love it.
I kept it at 150 mm of travel. After running it for so long I didn’t see a need to increase the travel. But who knows it might be fun to try.What travel did you maintain for the Yari? Was looking at a second hand Yari (which also came out of a Stympjumper) and thinking up upgrading it to a Charger 2 Damper as well as the Debonair Air Springs to around (170-180).
@2manytickets could you take a picture like the one I'm attaching of the I9 hub on your bike?View attachment 10478
So, bike upside down, taken on the non-drive side so that the camera is looking directly at the outer edge of the magnet & weld connecting the dropout and the seat stay. I'd like to see the gap and if my thingamajig might be doable for the I9 hubs.
Thanks in advance![]()
Ya I’ve done a few muddy rides. It’s going to happen sooner or later.Are they scratches on the bike on the 9th picture down?
Say whaaat on the bottom pictureNoticed it’s been a while since I’ve updated my post. I’ve ridden the hell out of the bike with no issues. I’ve been really happy with my upgrades, fork, tires, brakes bars and stem. I also installed an eagle gx 12spd was able to use BLEvo to bump up my speed limit. Any ways here are some pics. “Ride it like you stole it”View attachment 16912View attachment 16913
Auburn Ca on the culvert trail. When I got my levo it was one of the first production runs of 19 and was run an older version the software. I just got lucky.where is the jump on that bottom pic......
how did you increase speed using blevo on 19 model?
Yes the tire combo has work out great. I run 26psi front and 28psi rear and they hooked up way better than the butcher ever did. The rear has taken a beating but the front is holding up well. I think I might try a trail king for the rear next.Are you happy with your tires? In the wet the standard tires are so bad I can’t believe it. I have been using Continental tires for a long time on my normal bike and I like the we grip from the compound but don't know which tires to get so I consider the Der Baron/ Der Kaiser 2.4 tires as well.
