Coil suspension set up help
East Devon
Got a new stilus big mountain Z1 coil 170mm front and CR coil 170 mm rear
I am 110kg so looks like I need the yellow extra firm for the front
But no idea what I need for the rear current spring is 450 x 2.8
People seem to recommend cane creek progressive.
Any ideas or recommendations for a good experienced shop to contact.
I am based near Exeter Devon.
J-Tech have always been really helpful for me. They appear to have a new, more detailed spring calculator.
A progressive or not spring will depend on the kinematics of your frame I think.
Sprindex - adjust your suspension's coil spring rate here can you find some help. I´m 105kg with the gear and i bought the one with 540-610lb/in.
Then you have found your value can you buy the one that you like ride with. I´m gonna ride mine as long as that plastic adjuster doesn´t break. I don´t know about dealers on your island. Good luck!:)
    670K
